37" Tires
Old Jan 6, 2005 | 12:12 PM
oldschool's Avatar
37" Tires
Just want some opinions here. My set up is a '04 Ram 2500 4X4, turbo diesel, 48RE automatic trans., 3.73 gears. I have been doing some reading thats making me worry a little. I just installed 37" BFG's on my truck. Tell me that a truck designed to pull the weight that this is capable of, should not have tranny/hub issues turning these tires. There seems to be a ton of knowledge on this web site and any info. will be appreciated. Thanks in advance.
Old Jan 6, 2005 | 01:19 PM
cquestad's Avatar
You probably should have 4.10's with those tires...
But...I have tons of friends with 2nd gens 3.5 rear and 35's. They are in the same boat as you with even less power and they have had no issues.
Your best beat for drivability is to leave OD off till 60 with your set up. Or better yet...get all of the ATS goodies so you can control the way the tranny works. I have no problems with mine.
What lift and wheels are you running?
Old Jan 6, 2005 | 02:02 PM
oldschool's Avatar
I am running the stock aluminum alloy wheels with a 6" Tuff Country lift.
Old Jan 6, 2005 | 02:32 PM
cquestad's Avatar
Should work real nice...
May have front driveline issues that can be resolved by lengthening the front driveshaft. Listen/feel for "wierd" vibrations or noises. Make sure the track bar bolts and front top shock nuts are super tight. I learned both the hard way.
One solution to steep gearing is a TST.
Post some pics.
Old Jan 6, 2005 | 03:21 PM
bigblock2stroke's Avatar
37" tires with the 3.73 will give you a final ratio of less than 3.2:1. You would be alright with a manual trans, but your asking for trouble with a 48RE. With a torque converter upgrade you should be fine, but I bet you are shifting in and out of OD constantly with a very sluggish feel on acceleration.
I have driven a truck with those tires and a manual trans. It was definitely slow, but got good hwy fuel economy (20mpg at 75mph). the city economy was worse due to the rolling resistance (15mpg).
Old Jan 16, 2005 | 09:54 AM
Buddah's Avatar
I have an '03 Cummins six speed 3.73 with a Tuff Country 6'' lift and 37'' BFG's. I drove from Salt Lake to Temecula CA and got 16.5 mpg. I'm getting 15.5 to 16 mpg now in the winter.
May 29, 2009 10:24 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
sakisaki400
23
Dec 31, 2006 10:17 PM
