2nd gear won't lock
Old Oct 14, 2010 | 02:15 PM
ASHNBAK's Avatar
2nd gear won't lock
Not sure what's happening, but this started with 1st holding for a long time, even under light throttle, then going into second, and if floored it would sit on red line until into 3rd. Now, start in 1st, stacked shift into 3rd, then 4th and all is normal. I can force a shift into 2nd with heavier throttle, but it slips 100%, then into 3rd. Valve body, servo, have I damaged it bad?
Thanks.........
Old Oct 14, 2010 | 03:32 PM
redruM Hauler's Avatar
the sticking in first sounds like a throttle valve, the slipping in 2nd sounds like 2nd gear band or band clamp
Old Oct 15, 2010 | 08:12 PM
no_6_oh_no's Avatar
Check your front band adjustment, both problems can be caused by a loose adjustment.
Old Oct 15, 2010 | 08:49 PM
Raspy's Avatar
I'm thinking about adjusting mine. At 208,000 I'm now at about 120,000 since the new HD band went in. Any tips?
Old Oct 16, 2010 | 07:36 AM
no_6_oh_no's Avatar
Nope, set it stock specs and see how many threads are left. Then you will know if its time to replace.
Old Oct 20, 2010 | 04:03 PM
ASHNBAK's Avatar
Have been traveling and just got back to this......... thanks for the reply's. I'll take it to the local tranny shop and advise the outcome.
OrangeBlackHD
Jun 22, 2010 07:11 PM
xp8103
Jun 2, 2006 07:00 AM
mr T
21
Jun 1, 2005 08:48 AM
Nuttymopar
Sep 2, 2004 07:39 AM
damon_achey
Jun 7, 2004 03:33 PM
