2K RPM Vibration Revisited
Got one dealing with it dealer clueless. WHAT IS IT???? talk to a diesel mechanic today said some of the motors have weights in them and get out of time. then again he's talking mainly about cat's and other industrial equip. anyone have a clue if this might be the case
Originally Posted by i6DZUL
Not trying to rehash old memories, but I was curious as to how many still have vibe issues and how many miles have you put up with it.
Originally Posted by hammajamma
My truck has had it from day one,still does,65K miles.The rear drive shaft and u-joints have been replaced,no change.The driveline pitch angle was changed(shims) and that moved the vibration to about 70-75 vs. 65 to 70. I just try to stay below 70 until I can trade,hopefully in 07
Now theres a couple of things...replacing the bearings is only a band-aid with an out of round crank. Also, with mine, when I run with the OD off and hit 2k rpm's, I do not have a vibe....only vibes in OD at 65-75 mph. If the crank is the problem, why doesn't it vibe at 2k rpm standing still and while cruising out of OD?
I guess it's time to send an oil sample to Blackstone.
dodgedsl03
Jan 18, 2007 10:08 PM
rock
13
Jul 27, 2004 01:11 PM
fishin fever
Feb 22, 2004 08:32 PM
