2007 48RE with 5.9
Old Aug 26, 2007 | 04:57 PM
Mower Man's Avatar
2007 48RE with 5.9
Is the 48RE something to worry about if I leave the truck stock? Does it require more attention than the Ford and GM transmissions? Thanks.
Old Aug 26, 2007 | 05:07 PM
txfiremedic's Avatar
First off, welcome to DTR. IMO if you leave it stock, you'll be fine. Even with a mild, safe tuner I think you'd be fine.
Old Aug 26, 2007 | 06:21 PM
TrkEnvy's Avatar
Welcome to DTR.. the 48re has a bad rep because of all the torque that can be produced with an ENHANCED 5.9. If you leave it stock it is a great tranny and with normal service will last a long time. The 2 biggest killers of the 48re is slip (which creates heat) and heat. So if you tow heavy or like to be silly with the pedal I do recommend a torque converter..
Fronty Owner
Nov 17, 2007 12:44 PM
burners_banshee
Sep 10, 2007 02:03 PM
ID2500Ram
Apr 29, 2007 11:31 PM
