2004 ram 3500
Old Feb 13, 2013 | 08:06 AM
blue2002's Avatar
2004 ram 3500
I have a 2005 2500 auto. The problem I am having is after a while the pedal gets hard to push then when you push to a certain point it gets soft again. Like a compound bow.
Also on the shifting it shift fine till it goes to drive. It like jolts the truck. Now if your under a load it doesn't do it.
It has just a fass lift pump and banks IQ.
So any input would be greatly appreciated.
Old Feb 17, 2013 | 07:06 AM
blue2002's Avatar
well I guess no one has any input. Im going to try the BD noise isolator to see if its noise then.
Old Feb 17, 2013 | 10:35 AM
madhat's Avatar
Administrator/Jarhead
Man, I don't know. My truck actually has a cable, but I can't remember if the 05s had the APPS and no cable. Check behind the petal, make sure something isn't going on back there.
I'd look for a physical problem first with the assembly itself, then go from there.
As far as the shifting, do you mean when you put the shifter into drive, or when you're driving and it shifts into fourth gear?
misterJP
17
Oct 23, 2010 01:15 AM
JayRay
Introductions / New People
Mar 2, 2010 11:03 AM
Tow Truck Ram
May 11, 2009 09:32 PM
twhman
Feb 22, 2007 11:29 AM
BIg Kahuna
0
Jun 26, 2005 03:24 PM
