2004 2500 ram brake noise rattle?
Old Mar 6, 2011 | 10:03 AM
crslush's Avatar
Question 2004 2500 ram brake noise rattle?
Hello I have a 2004 2500 Ram with 85,000 miles, brakes were redone at 55,000 with rotors and ceramic pads, I live on a dirt road and for about 3 months and it is been getting worse as time goes on but there is a loud rattle when hitting large or small bumps in the road I assume it has to do with the brakes because when i just tap the brakes or hold them on ever slightly it goes away, I dont know if anyone else has experienced this, I dont think any bolts are loose (I havent put a wrench on them but have looked under the truck and everything looks tight) I was thinking mambe the rubber bushings in the calipers are shot? or is it something else? any thoughts would be greatly appreciated. its starting to drive me nuts!
Old Mar 6, 2011 | 12:40 PM
.boB's Avatar
Could be a lot of things besides a loose caliper. Pull a wheel off and take a look around.
Old Mar 6, 2011 | 01:26 PM
torquefan's Avatar
The fact that the rattle goes away tells me a caliper or a pad is loose, and when the brakes apply, the friction is holding it tight.
Climb under the truck and give each caliper a little shake. A bit of movement is normal because the pins go through rubber, but there shouldn't be a rattle. If one rattles, it's possible the rubber slide bushing is worn away, or has fallen out.
The next possibility is that there may be a missing stainless steel slide missing on the rail that the pads ride on. You may have to take the wheels off to check this one, but you can get a small screwdriver and push each pad up and down to see if there's any excessive clearance. The pads shouldnt be able to move up/down a whole lot.
Old Mar 6, 2011 | 02:17 PM
Adaminak's Avatar
Been there, had the same frustration! Turns out the caliper bolts were bottoming out before they tightened all the way. Two grade 8 washers later and all was well again. No more noise for the last 18K miles.
Old Apr 4, 2011 | 06:38 PM
crslush's Avatar
just to let evryone know I found out the brake pad was rattling on the caliper mount, just sanded the spot with a disk sander and it did the trick. thanks for the help
Donmacky
Feb 1, 2014 06:07 PM
marksblaster
Oct 27, 2012 11:26 AM
CrawlinDodge
Oct 14, 2010 10:28 PM
