2003 SO/HO Questions ?
Old Apr 22, 2006 | 02:59 PM
lucey's Avatar
My father in law is looking at a 2003 with 86,00km. I was wondering what the difference is in the way of fuel mileage between the two. Are there any other things other than the 47/48RE issue that i should be aware of ?
Old Apr 22, 2006 | 03:18 PM
bulabula's Avatar
I am not aware of any fuel mileage differences - SO vs HO given the same tranny.
Other things to look for? The cracked alternator bracket (or fix) and the cruise control recall (CO2). I think there are/were TSB's for them. There should be a little sticker somewhere under the hood for the CO2 (there isn't on mine - I told them to leave it off); and I'm still running the original alternator bracket.
Is the truck a 2500 or 3500? I am not aware of any 47RE/48RE issue back then - it's been a while but I don't think the 48's were offered in '03? They weren't when I was shopping. I wanted a stick and never paid to much attention the slush box's. The auto 2500's got the little rear end; the sticks should have the bigger one; all the 3500's got the bigger rear.
I remember the threads about some trucks having body plugs installed, and some not. I also recall that some of the real early guys (when I got mine) with 3.73's got new ones installed.
Old Apr 22, 2006 | 03:53 PM
MikeyB's Avatar
The 48re tranny became available in the early spring of '03.
I would think the SO gets slightly better fuel economy since it's detuned compared to the HO. But try to get a HO, the extra power is worth it.
MikeyB
Old Apr 22, 2006 | 05:02 PM
bubba33's Avatar
no real differance in mpg from SO to HO.The 48RE came out in jan of 2003.The rear ends are the the bigger ones 11.50.
Old Apr 22, 2006 | 07:17 PM
Rolngthun's Avatar
I had a late 03 305 engine. It is a great engine. Better then the 325 engine I have now. That 305 HP engine had better response and waay better fuel mileage.
Old Apr 22, 2006 | 10:56 PM
lucey's Avatar
So the SO is a worthy engine. Now what about the 47RE ? Was it the tranny with all the issues or was that the 47RH ?
Old Apr 23, 2006 | 12:05 AM
bubba33's Avatar
that truck he is looking at could have the 48Re in it with a SO. Depends on the build date. I personaly would rather have the 48RE.
Old Apr 23, 2006 | 05:39 AM
Dodgezilla's Avatar
The SO is worthy if you spend a couple bucks on it.
It's kind of a slug without performance mods though......
Old Apr 23, 2006 | 08:55 AM
lucey's Avatar
This is really starting to get to me. I ran the VIN with the forum breakdowns and it shows the SO and i called a very reputable dealer and they sent me the breakdown sheet and it also shows it as a SO with the 47RE. My father inlaw says he has called 8 dealers and they are all telling him it is a 305. What gives ? This is the VIN103KU28633J552681. Is there any way this could be a 305 ? I am under the impression they never made the 305 with the 47 tranny.
Old Apr 23, 2006 | 12:04 PM
Dodgezilla's Avatar
You are correct. The HOs have never come with a 47re trans. Only a 6 speed or the 48re. Can't help on the VIN number though.
I know everyone will recommend the HO, and yes it's got more power, BUT the SO will still pull and run just fine....
Old Apr 23, 2006 | 12:11 PM
oestreich84's Avatar
The vin number is actually 1D3KU2863 3J552681. I checked a site that tells you if you have any open recalls for the truck and it came up with the out of park alarm system recall. Here is the site http://www.dodge.com/webselfservice/...m%28%27R%27%29
It doesnt say what engine it has though.
On edit: I tried a vin search, but it said that the vin number was wrong. I am confused now
Old Apr 23, 2006 | 12:24 PM
bulabula's Avatar
<snip> ... My father inlaw says he has called 8 dealers and they are all telling him it is a 305. What gives ? ... <snip>
As far as dealers go, just because dealers sell them doesn't mean that the people you are talking to (especially on the phone) know what the heck they're talking about: the closest Dodge dealer here still paints "Cummings" on the windshields of the trucks on the lot.
If the VIN says its an SO with a 47RE, it probably does.
Then again, if your father in law wants to buy it, for whatever the reason - SO or HO or..., and it doesn't really matter to him, I say go for it; they're all good trucks.
Old Apr 23, 2006 | 12:54 PM
1sttruck's Avatar
The sticker on engine notes the power output, the sticker in the glovebox notes the options.
Old Apr 23, 2006 | 12:55 PM
qmcdt's Avatar
The HO has oil cooled piston crowns, a different CP3 pump (larger capacity) and I think larger injectors (not 100% pos on the injectors though.)
Old Apr 23, 2006 | 02:57 PM
lucey's Avatar
Well we can put this one to bed. It is a SO with the 47 tranny. He still went ahead and bought it. Hopefully it will be a good truck.
