2003 Hard Start
Old Aug 6, 2007 | 09:56 PM
Daimler Dan's Avatar
2003 Hard Start
Lately my 2003 HO takes 4-5 seconds of crank time to get started. Once or twice, it has died a few seconds after it has started.
Suspecting fuel supply issues, I looked into the lift pump. I bumped the starter (like I used to do after I changed the fuel filter) and did not hear the pump run.
Doesn't the lift pump usually run for at least a few seconds after the starter is bumped?
She sounds dead. Can the truck still run with a dead lift pump?
Thanks!
Dan
Old Aug 6, 2007 | 10:55 PM
Smithereen's Avatar
Yes it can. I suspected mine went out and got the dealer to check my codes and found that mine quit 84 key-ons ago. Got replaced with the in tank one under warranty. So if the pump quits in the right position, the truck will still run. Get the codes checked or do the 3 key-on - key-off to check to see if any codes show.
kodeman84
Aug 7, 2011 08:46 PM
Steelie73
Jan 25, 2010 04:52 PM
Jimmy RockAway
Oct 5, 2009 09:12 AM
Jimmy RockAway
Sep 26, 2009 07:55 PM
joeel
Dec 6, 2006 09:22 PM
