2003 Dodge Ram Diesel won't start in cold or wet weather
Old Oct 9, 2009 | 11:58 AM
Dodge Mack's Avatar
It either won't start at all or cranks for like 10 seconds b4 firing, I'm now having to plug in the block heater when it's +5 degrees celcius (42 degrees Fahrenheit) or colder. I've replaced the fuel injector pump and the transfer pump, had a few computer updates and still the same problem. Anyone had similar problems?
Old Oct 9, 2009 | 12:42 PM
pullin hard's Avatar
is the grid heater working? fuel filter clogged? check the basics
Old Oct 9, 2009 | 12:44 PM
Dodge Mack's Avatar
new fuel filter and had the grid heater checked and they say it's working and I can hear it come on and turn off
Old Oct 9, 2009 | 01:14 PM
masterphreak's Avatar
Maybe a bad injector. If one is leaking it will bleed the presure in the rail and cause a hard start/no start condition. Run a search on here there are several threads that cover this issue.
Good luck and hope you get your truck fixed.
Old Oct 9, 2009 | 03:18 PM
have a good shop or dealer check the injectors for return rate, if they can or have them shut the injectors down one at a time.
Old Oct 9, 2009 | 06:52 PM
longbed's Avatar
Your injectors are no good one or some. My 03 was the same.How many miles do you have ? I pluged mine in for 40000 mile then they would not start at all even warm. Changed them and it starts right up any weather.
Old Oct 9, 2009 | 07:00 PM
Dodge Mack's Avatar
injectors?
Thanks guys, but will having it plugged in make a difference if the injecotrs are pooched? What's the cost of replacing injectors?
Old Oct 12, 2009 | 11:15 AM
Dodge Mack's Avatar
What was the cost of replacing and did you replace them all?
Old Oct 12, 2009 | 11:59 AM
rich's Avatar
their about 400 ea usaully if one goes others will follow
Old Oct 12, 2009 | 05:12 PM
Dodge Mack's Avatar
Let me guess...there's 8? Was yours difficult to start in rainy weather too? I've got 190000km and the problem started back around 170K.
Old Oct 12, 2009 | 05:38 PM
Purplezr2's Avatar
There are 6.
Root
16
May 4, 2016 05:53 PM
kodeman84
Aug 7, 2011 08:46 PM
Browncow71
Jan 26, 2010 12:52 PM
joeel
Dec 6, 2006 09:22 PM
Bampa
Apr 10, 2003 08:36 AM
