2003 Dodge No start, No communication
Old Nov 21, 2018 | 01:04 PM
Xtremfury's Avatar
2003 Dodge 2500 Diesel, 2wd, Auto. This is the 3rd time that this has happened, pay dealer and private garage to diagnose a bad ECM, change ECM, still nothing, have electronics guy check original ECM and find nothing wrong with it. Reinstall original ECM after 2 months of truck sitting and truck runs for 2 years without a problem (No changes to anything at all)...Now same old same old.....truck will not start, turns over good, no communication with ECM. After key is turned, 'Park Brake' light illuminates and dings, 'Air Bag' light illuminates and dings, gauges do not move and red security light stays lit. I see another thread for a 2006 with similar problem, they note that it may be a viscous fan issue and to remove #6 fuse however #6 fuse on my truck is 'Air Bag', that did not solve my problem upon removal of said fuse. I don't think it is an ECM problem, there has to be something like a sensor or module failed or failing that is blocking the ECM from functioning normally or even identifying a problem. Dealer ran through their checklist and their solution is bad ECU, so why does ECM check out good but still not run?? And then when I put the original ECM back on so I can send to the scrap yard, have 2 years of absolute trouble free driving?? Truck ran great, shut it off and now this again.
Old Jan 2, 2019 | 01:41 AM
Dark Side's Avatar
On your 03 there is a plug near the bottom of the Rad that supplies the fan, You could try unplugging that to eliminate the Viscous Fan.
There are a few plugs that are prone to problems you could try taking apart, cleaning and plugging back in. Behind the Drivers side Mud Flap. Back of engine at the top where it bolts to the transmission. Large plug behind Drivers side battery ... ( I had to use drill guides to drill the head of that bolt off then replace the bolt ) Plus there are 2 wires taped together running down to the computer from the Batt terminal of the fuse box and a ground (Mine showed signs of having ran hot distorting the tape)
My problem ended up being the ECM and I In Boxed you information on that. With the off again on again nature of your problem I would be going after the plugs I mentioned and take a day to find and clean all the grounds in and around the engine compartment even if they look good.
Old Nov 12, 2024 | 07:11 AM
NIOMARVIN83's Avatar
It sounds like you're dealing with an intermittent issue that’s tough to pinpoint. Here are a few things to check:
Fuses and Relays: Make sure all the fuses and relays connected to the ECM and engine are in good condition. Sometimes, a small issue with these can cause big problems.
Ground Connections: A bad or loose ground connection can cause problems with the ECM. Check the grounds to ensure they're clean and secure.
Wiring: Look for any worn or damaged wiring, especially around the ECM and sensors. A short or break in the wiring could cause a lack of communication with the ECM.
Security System: The red security light staying on might suggest an issue with the vehicle’s security system, preventing the ECM from starting the engine. You may need to check or reset the security system.
Modules and Sensors: You’re right that it could be a sensor or module issue. The truck may not be getting the right input from one of the critical components, which could block ECM communication.
Since you've had issues with the ECM in the past, it’s also worth trying another diagnostic approach, maybe using a different scanner, to make sure all codes and modules are being read properly.
It could be a combination of issues, but start by double-checking the basics like wiring and grounds before diving back into the ECM.
Old Nov 24, 2024 | 07:42 AM
47Dodge's Avatar
He says the park brake light illuminates as well as the air bag and security. I wonder if those 3 systems share something in common like a wire or ground that is causing the issue and his security system is preventing the truck from being started?!
47
bill50cal
Nov 5, 2020 01:04 PM
Dynocon
Jun 23, 2015 01:36 PM
NE frmhnd
Big Rigs
Oct 11, 2012 11:05 PM
SilverSootXpres
Feb 26, 2007 10:24 PM
emfc_22
Nov 5, 2006 07:49 PM
