10.5 rear axel fill mark
Old Mar 8, 2007 | 07:02 PM
kully560's Avatar
I have a 2003, with a 10.5 rear end and I will be doing the change myself.but how far to the fill hole do I fill it, how much gear lube, also foot lbs for bolts. thanks
Old Mar 9, 2007 | 08:50 AM
Blast Chamber's Avatar
I have the same axle. There is a TSB out that says to fill the 10.5" AAM axle to 1" below the hole, +/- 1/4". Apparently if you don't do that, it could cause "foaming". Personally, I think that's crap and just filled mine to the bottom of the hole like any other axle. No problems so far in the 20k miles since I changed it.
http://dodgeram.info/tsb/2004/03-001-04A.htm
I bought a gallon jug of Amsoil Long Life Synthetic Gear Lube SAE 75W-90 at Napa. You'll probably need around 3 quarts of it. Be careful not to overtorque the cover bolts. I just snugged them up with a 3/8" ratchet and had no leaks. You can re-use the original gasket after cleaning it up.
Old Mar 9, 2007 | 01:31 PM
kully560's Avatar
great thanks for the help.
Busboy
May 12, 2014 07:23 AM
sullivad
13
Dec 18, 2006 08:47 AM
JImbo1
Apr 9, 2003 07:46 AM
yz
Nov 25, 2002 06:04 PM
yomitch
Nov 22, 2002 12:11 AM
