1-2 shift stutter
1-2 shift stutter
Greetings from Indiana! I am having problems with the 48re in my 06 Ram. At low speed-light throttle it cant make up its mind if it wants 1st or 2nd gear. I have already had the TSB for the gov transducer with no luck. The dealer then replaced the valve body, problem is still there. The truck is stock with the exception of a programmer. The truck does this with the stock calibration or the programmer.Any ideas? Also any opionions on who has the best shift kit? I dont want anything that will knock the dash out of the truck, just a good firm shift.Thanks!
Thanks for the opinions! what does a "DTT shift enhance" do? As for the gov pressure soleniod, I'll have to go through my maintance records but im pretty sure that was replaced. Even if it wasnt changed the first time, it was changed when the dealer replaced the valve body.
A Transgo shift kt is a great replacement also as it will kick the pressures up enough to keep the sloppy shifting at low throttle out of the equation.
Here is a nother solution you might wat to look at for a truck that just doesn't want to respond to the shuttle shift fixes. It replaces the OEM solenoid with a bigger less problematic one use din the GM units. These almost never go bad and will stand a lot more pressure flood from the line pressure circuits.
'strokeThis_'07
Aug 9, 2008 01:49 AM
Charlie8301
15
Feb 27, 2005 09:09 PM
Racnmasn1
Dec 10, 2004 07:33 AM
