'07 5.9 P2146 - Nothing obvious
Old Aug 21, 2020 | 06:36 AM
cal74's Avatar
Have an '07 5.9 that was running perfectly and the next morning threw a P2146 code and is now running like crap. I ohm'd the harness and the injectors, all were well within spec with the 2nd injector being I believe .3 (others were .1). I ended up replacing the valve cover gasket (harness) and same issue.
Do I just assume it's number 2 injector, even though .3 shouldn't be an issue. All other wiring looks good, tried disconnecting the batteries a few times, batteries fully charged, etc. The truck is a garage queen and is spotless.
Thanks for any help
Old Aug 21, 2020 | 09:21 AM
FMB's Avatar
FMB
Originally Posted by cal74
Do I just assume it's number 2 injector, even though .3 shouldn't be an issue. Thanks for any help
Using an IR Thermometer like
this"><span style=this" /> this">this
, check the temps at each cylinder's exhaust port and you will probably see #2 much lower than the others. If so, it's probably time to pull the injector. There are several options.
  1. Pull #2 and replace it, or
  2. Pull all 6, send them out for testing and rebuild,
  3. Replace all 6.
On my '03, I had one go bad and sent them all out. Several were borderline. I had them all rebuilt by F1. Engine ran great afterwards.
Back to morning brew . . .
Old Aug 21, 2020 | 11:24 AM
cal74's Avatar
I'll try that - It's got 98,000 on the clock and I've had a 2 micron filter on since 60,xxx - Always run extra fuel lubricant. If money were no object, I'd throw six new sticks on but I'd rather not at the moment.
Old Aug 31, 2020 | 12:14 PM
bonus's Avatar
Let us know how it goes, and good luck.
Old Sep 1, 2020 | 07:40 AM
cal74's Avatar
I did temp them and #2 was slightly cooler after running a minute or so.
I also than hooked up a better code reader. I had just pulled the first code with my Edge Monitor. When I hooked up the code reader I was able to get a code (can't recall what) for cylinder #2.
I ordered a new injector solenoid and installed it and it fired right up. Wasn't a bad install and I'm going to order an extra to keep in the tool box, just in case.
Old Sep 2, 2020 | 12:38 PM
bonus's Avatar
Great Info, thanks for posting.
Jason Mischke
Apr 17, 2018 07:11 PM
snocross78
Aug 26, 2010 11:25 AM
bumpytruck
May 26, 2009 02:33 PM
Roperteacher
Feb 29, 2008 10:00 PM
