Is the 06 Auto stronger???
Old Aug 21, 2006 | 05:45 AM
Nick Bazil's Avatar
I have read that the 06 Auto is stronger than the other years?? Is this true?? They said that they had to beef it up so they could use the exhaust brake....
Old Aug 21, 2006 | 07:15 AM
Smokeman's Avatar
I'm not sure when it was upgraded but the 06 literature says "Count on ultra-strong planetary carriers - recently upgraded to a six pinion design. There's high converter clutch pressure and capacity, with added capacity on all clutches and bands. This transmission can now engage the converter clutch in 2nd, 3rd, and 4th gears, and a revised hydraulic pump offers 15% greater flow capacity over previous models for better cooling and durability."
As I mentioned I'm not sure when this took place whether it was this year or 05 or 04 but somebody will chime in with the info.
Old Aug 21, 2006 | 12:16 PM
Peterbilt's Avatar
Sounds like all the 48REs. For the 06s, they revised the #5 thrust washer (I think it's coated now) for use with e-brake. I belive only hardware change. The software changed a bunch though.
Pete
KVD
Jul 3, 2007 06:38 PM
KVD
Dec 15, 2006 05:39 PM
kelownadiesel
Nov 15, 2006 11:56 PM
MNorby
Mar 27, 2006 12:39 AM
