06 48re and Jake Exhaust Brake
Originally Posted by burlhall
Thanks for all of the thoughtful replies. I realize that a manual transmission would be the best for towing but I'm not sure if I would like driving a manual when I'm not towing. I'll have to give it more consideration. I probably should test drive a manual to see how I like it. Several years ago, I wouldn't want anything other than a manual transmission. Who knows, I might really like driving them again.
LarryB01, I'm not familiar with the controller that you spoke of. Where can I get more information? Sounds like just the solution I was looking for.
If you can hold out for the controller, I would. My 04 is GREAT, just pulled my first big tow this weekend(look at my gallery for unit pulled). The shifts are hard but I'm learning how to apply the power. Should have put in the billet shafts....
tom
tom
Originally Posted by puller
We have a 2006 3500 dually CTD with auto tranny and a Jake brake installed. From what I understand the transmission works differently than the previous years(this is my first Dodge). The 06 tranny has a switch on the gear shift and when you push the button 1 time it is in tow/haul mode push it again and it is out of overdrive mode. When you pull the Jake brake button it starts down shifting right away. I have not pulled our trailer very much but when I have it seems to work just GREAT, you hardly have to hit the foot brake at all.
Puller
Puller
Anyway, I am planning on getting the factory exhaust brake as well. But the truck won't be in until end of December. So can't give any actual opinions at this point.
Ken
According to the owners manual Page #262 "You press the TOW HAUL O/D OFF" button once to select tow haul this will improve performance and reduce the potential for transmission overheating or failure due to excessive shifting. When operating in TOW HAUL mode, 5th gear is disabled and 2-3 and 3-4 shift patterns are modified. Shifts into Overdrive (4th Gear) are allowed during steady cruise (for improved fuel economy) and automatic closed-throttle downshifts to 3rd gear (for improved braking)will occur during steady braking. Pressing the"TOW HAUL O/D OFF" button a second time to select O/D OFF will disable 4th and 5th gear completely, which should eliminate any excessive transmission shifting.
When you push the Tow haul button once the tow haul light on the dash lights up, when you push the button the second time the O/D Off light on the dash lights up.
I hope this clears this up.
Puller
Puller
Puller
Puller
Ken
Originally Posted by abc4yew
Guys, The '06 auto is a 5 speed??? ks
They are right. The mechanical chages to handle the exhaust brake were implemented in all 2005's (and some 04.5's from what I'm seeing). It's the software that you need to be able to run the exhaust brake on your 05 48RE. Not sure when they'll release a reflash for the ECM.
jake
Originally Posted by Jeff in TD
I'm kind of in the same boat you are... Thinking of trading in for an 06 dually, and possibly getting a HEAVY 5er that will require 4.10's.
I like the stick shift I have now, but I'm not a big fan of the new G's lower high gear ratio, nor do I like the idea of a dual mass flywheel. The auto now has both a tow/haul mode that changes shift points, and a OD lockout, plus factory approved for Jake.
With the auto getting better, and the stick shift taking a back slide, my next truck may be an auto...
Would like to hear from someone who actually has an 06 auto, and tows heavy with it...
Mike, I really like my Jake on my stick shift, but I really can't be of much help when it comes to giving you advice on what to do with the auto...
About all I know is that there needs to be some sort of modification done to lock the torque converter, or else the tranny will overheat promptly. There may also have been some sort of thrust bearing that needs to be upgraded...
Anyhow, I'm sure someone who knows more will chime in to help you out.
Originally Posted by J BODY
I've installed two Jake Brakes on 06 48re equipped trucks. One for a customer and one is on the lot. Nice feature and it works great. I'm REALLY liking these 06's!
I was in the dealer last week with my 05 on the rack and it has the newer 48re in it but it doesn't have the newer tow-haul mode.
If its just software is this something that can maybe be reflashed to the newer settings?
And other then not being able to lock up second gear why would an 06 be better suited to handle a jake then an 05 with the same tranny?
Originally Posted by DrMoab
So other then software what is the differnce between an 05 48re and an 06 48re?
Originally Posted by dcwilson
I was told by the dealer (Service Manager in Victorville) that the 06 ECM has more memory, and you cannot flash an 05 ECM with the 06 code.
Based on a thread I read on this Board, or on the TDR Board, the 05 ECM is sufficiently large to add programming necessary for the 48re to work with an exhaust brake. However, the ECM in the 04.5 and earlier models is not large enough. Based on what I have read on these Boards, it sounds like Dodge has just made a business decision (ie, not given priority) not to provide the necessary programming for the 05 model year. In my opinion it may have to do with not wanting to provide a 7/70 warranty for trucks having this capabilty. Maybe in 2-3 years when most 05 trucks are about out of warranty this programming might be made available. Given all of the profitability problems auto companies are having, I doubt if they will be doing anything that might add to warranty expenses. I hope I am wrong.
