04.5 4X4 Ball joint problem...Anybody?
Old Mar 15, 2005 | 10:29 PM
Tiara3100's Avatar
Getting ready to take my truck to the ******* to have him look at the front end. When I go over a speed bump or hit a pot hole, I get a clunking/popping noise from the passenger side front end. I'm thinking ball joint. Any one else have this problem??
Old Mar 16, 2005 | 02:43 AM
SuperGewl's Avatar
I had the same problem except when backing up out of the drive way and turning the wheel. It was worse when raining after the truck would sit for a spell. The dealer said they had to tight up some of the front end components that wer loose. I will try to find out what the actually did and let you know tommorrow.
Old Mar 17, 2005 | 05:54 PM
hoser's Avatar
check the bottom shock bolt, if youve put on shocks lately , that could be it. Use a bigger snipe to over tighten it
Old Mar 17, 2005 | 07:25 PM
Tiara3100's Avatar
Haven't touched a thing on the truck. As the signature says "Bone stock". Gonna leave it stock for the warranty...I will drop it of at the dealers monday...let you know.
Old Mar 17, 2005 | 09:19 PM
SuperGewl's Avatar
Check the lower control arm bolts. They have been loose on various trucks and mine also.
Old Mar 19, 2005 | 05:45 PM
ddutil's Avatar
My Lower joints are both worn out, 2x4 truck. Are they the same part than on 4x4, and does anybody has a part # for Moog or any other, adjustable or not?
I posted the same question on TDR. Thanks guys, any help will be appreciated.
Dan
2003 ETH-DEE 2x4 Quad SB, 46k miles on odo, and a few goodies installed
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
FDC
Jul 16, 2007 12:51 PM
