04 3500 clutch compressed, RMPS dip below 500???
Old May 12, 2009 | 05:52 PM
CTDP830's Avatar
no codes. clutch goes in, RPMS dip below 500 and then back to regular. even when im in neutral rollin to a stop or jus shiftin gears. its had a few rough starts but no big problems. tech at dealership cant figure it out. any suggestions??? pump, lift pump, cam sensor, injectors????
Old May 12, 2009 | 05:59 PM
tool's Avatar
Does it seem to be lugging down when you push the clutch in?
Any noise or vibration?
Throw out bearing?
Old May 12, 2009 | 06:10 PM
HotRodTodd's Avatar
Lets figure out if its mechanical or electrical.
After starting the truck, unplug the clutch safety switch, then operate the clutch in and out and see if it still does it.
If it doesn't do it then it is electrical. If it does do it, then its mechanical.
Make sense ?
Old May 12, 2009 | 06:20 PM
CTDP830's Avatar
lugs down, replace a u joint that was making my truch shutter but no noise vibration.
Where is the clutch safty switch? makes sense but ive had people tell me its a fuel problem, but ill try what you say.
Old May 12, 2009 | 06:26 PM
HotRodTodd's Avatar
Right above the clutch pedal, looks like the brake light switch.
Old May 12, 2009 | 07:17 PM
CTDP830's Avatar
I had one of my friends put the computer on it and nothin came up. its gettin to the point where it wants to cut out and shut off. cant find the switch he doesnt kno either. im gonna take it back to the dealer ship or to one of the shops that do work for them. thanks for the help if you think of anything let me know dont think its the clutch, i can rev it up and the rpms drop the same.
johnr9q
28
Apr 27, 2012 11:03 AM
Big Blue24
Mar 16, 2007 09:49 AM
the_fox_man4
Oct 23, 2006 11:42 AM
Hummin Cummins
Feb 11, 2003 12:14 PM
