03 new to me problems, questions
i bought a new key fob, went to program it and noting happens when i turned the key to acc. no radio, no nothing, no acc will powered up with key turned to acc.??? what gives?
the 16 pin data-link is not marked, which one is pin #1 and #4 for the paper clip/wire jump to program the new key fob. my defroster stuck on for a day, now all the blend doors are functioning properly??? the indicator for park does not go to park all the time, the square light the surrounds the P does not elluminate sometimes, when it does that it will not crank/start. is that adjustable? Thanks! |
You need to take it to the dealer to have the key program to your truck if not all you have is a door key.
Hold on a second....
On the 03's, it's just a key, no electronics... unless it's an upgrade. You just have a key with a black head with a ram on it, right? Does your other key still work? You're just talking about the small, three button key fob, correct? Lock, unlock and panic? I'll look for the diagram for the 16 pin OBDII connector. Blend doors and recirc doors are a huge issue with 3rd gens. Do a search, you'll find the parts you need. My shifter does that from time to time. You can go under the truck and find the cable and adjust it. Just make sure that the truck's emergency break is on or the wheels are chocked... safety first! If you're having a no start issue from this, put it in neutral and make sure it starts there. If it does not, you may have a bad neutral safety switch. Let me look for some diagrams and such... be right back. |
STANDARD PROCEDURE - RKE TRANSMITTER
BATTERIES NOTE: Do not disturb the metal terminal near the batteries. Avoid touching the new batteries. Skin oils may cause battery deterioration. If batteries are touched, clean with rubbing alcohol. The Remote Keyless Entry (RKE) transmitter case snaps open and shut for battery access. To replace the RKE transmitter batteries: (1) Using a thin coin, gently pry at the notch in the center seam of the RKE transmitter case halves near the key ring until the two halves unsnap. Be careful not to damage the rubber gasket when separating the case halves. (2) Lift the back half of the transmitter case off of the RKE transmitter. (3) Remove the two batteries from the RKE transmitter. (4) Replace the two batteries with new 3V lithium 2016 cell. Install the batteries with the positive terminal up. Reference the “+ SIDE UP” on the inside of the bottom half of the transmitter case. (5) Align the two RKE transmitter case halves with each other, and squeeze them firmly and evenly together until they snap back into place. Test transmitter operation. STANDARD PROCEDURE - RKE TRANSMITTER CUSTOMER PREFERENCES AUTOMATIC (ROLLING) LOCKS The rolling locks feature can be toggled ON/OFF by using the DRB IIIt only. HORN CHIRP DISABLING / ENABLING The horn chirp can be toggled using a DRB IIIt or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To DISABLE (cancel) the horn chirp feature: (1) Enter the vehicle and close all doors. (2) Fasten the seat belt (this will cancel the seat belt chime). (3) Turn the ignition to the ON position. (4) Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the UNLOCK button. When a single chime is heard, release both buttons. (5) Turn the ignition OFF. (6) Turn the ignition ON or wait 60 seconds. (7) Test the horn chirp feature by pressing the LOCK button. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To ENABLE the horn chirp feature, repeat the above procedure. OPTICAL CHIRP (FLASH) DISABLING / ENABLING The optical chirp can be toggled using a DRB IIIt or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To DISABLE (cancel) the optical chirp feature: (1) Enter the vehicle and close all doors. (2) Fasten the seat belt (this will cancel the seat belt chime). (3) Turn the ignition to the ON position. (4) Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the PANIC button. When a single chime is heard, release both buttons. (5) Turn the ignition OFF. (6) Turn the ignition ON or wait 60 seconds. (7) Test the optical chirp feature by pressing the LOCK button. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To ENABLE the optical chirp feature, repeat the above procedure. UNLOCK SEQUENCE The unlock sequence can be toggled using a DRB IIIt or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To toggle between Driver door first and Unlock all doors function: (1) Enter the vehicle and close all doors. (2) Fasten the seat belt (this will cancel the seat belt chime). (3) Turn the ignition to the ON position. (4) Press and hold the UNLOCK button for 4 seconds. Within 6 seconds with the UNLOCK button still depressed, press the LOCK button. When a single chime is heard, release both buttons. (5) Turn the ignition OFF. (6) Turn the ignition ON or wait 60 seconds. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To toggle this feature, repeat the above procedure. STANDARD PROCEDURE - RKE TRANSMITTER PROGRAMING New Remote Keyless Entry (RKE) transmitters can be programed using the DRB IIIt scan tool and the proper Diagnostic Procedures manual. The DRB IIIt scan tool can provide confirmation that the PCI data bus is functional, and that all of the electronic modules are sending and receiving the proper messages on the PCI data bus. The following procedure can be used as long as one programmed transmitter is available: NOTE: When entering program mode using that programmed fob, ALL currently programmed fobs will be erased and they will have to be reprogrammed for the vehicle. If program mode is entered and no action is performed, the previously programmed fobs will continue to function. (1) Enter the vehicle and close all doors. (2) Fasten the seat belt (this will cancel the seat belt chime). Turn the ignition to the RUN position. (3) Press and hold the UNLOCK button on a programmed transmitter for 4 to 10 seconds. Within the 4 to 10 seconds with the UNLOCK button still depressed, press the PANIC button for one second. When a single chime is heard, release both buttons. The chime indicates the system is in program mode. (4) Press and release both the LOCK and UNLOCK buttons simultaneously on a fob to be programmed. A single chime will be heard, this indicates the fob has been recognized. (5) Press and release any button on the same fob. A single chime will be heard, this indicates the fob has been programmed. (6) Repeat steps 4 and 5 for up to a total of 4 fobs. (7) Turn the ignition OFF. (8) Turn the ignition ON or wait 60 seconds. The vehicle will remain in program mode for up to 60 seconds from when the original chime (step 3) was heard. After 60 seconds, all programmed transmitters will function normally. SPECIFICATIONS - REMOTE KEYLESS ENTRY TRANSMITTER RANGE Normal operation range is up to a distance of 3 to 7 meters (10 to 23 ft.) of the vehicle. Range may be better or worse depending on the environment around the vehicle. |
1 Attachment(s)
Originally Posted by madhat
(Post 3057129)
On the 03's, it's just a key, no electronics... unless it's an upgrade. You just have a key with a black head with a ram on it, right? Does your other key still work? You're just talking about the small, three button key fob, correct? Lock, unlock and panic? Blend doors and recirc doors are a huge issue with 3rd gens. Do a search, you'll find the parts you need. yes the 3 button just like my 99 i did a search a day after the original post, yep, i have the same huge problem. i discovered turn mode on first then the fan on and it works kinda. Thanks for the information! i googled the programming of a key fob for a 03 and found jump #1 and #4 puts it in program mode, cant try it cause the acc will not power up. i did talk to a Dodge dealer mechanic yesterday, he took a quick look at it, the acc no power up may be in the aftermarket remote start system he said? |
Yes, a remote start system will screw all kinds of things up. I had one... key word had.
Pull your steering column cover off and your knee bolster, look at all the stuff the remote start is connected to, see if anything is loose. If you don't see anything, find the remote start box and get the installation manual, trouble shoot from there. Does the remote start work? If it does not and you don't want it, get all that crap out of there. Just make sure you repair any splices/taps etc that are there. |
yes it works sorta. it doesn't crank long enough to start sometimes. problem #2 when i leave the truck i hit the arm button to lock the doors and my wife or kid gets in with there key the alarm goes off until someone gets my remote hits the disarm button (i only have 1 of them remote)
that's exactly what i am going to do, scrap it or replace it. i have talked to 3 people locally, 1 being the Dodge mechanic, they have all referred me to ASA Auto, small aftermarket install shop. they specialize in remote starts. i checked with Dodge yesterday, 03 is not offering a Mopar remote start, 04 and up only. if it was offered i would take it there and have them install one and fix everything. I'll go see ASA after the Holidays. Thanks again. |
Man, there isin't a factory remote start for my truck. I think the 06's were the first year... maybe 05's. My wife's 08 has one.
Something like that, it's better to get a pro to do it unless you really know what you're doing. The one I had installed worked great for about 3 years, then it started taking a crap on me. After about two weeks of fooling with it, I gave up. Good luck. Let us know what happens. |
i hope i have the years correct, it is not offered for a 03.
you from Yuma AZ? we may be going there for a sand drag race there in 2012, not sure for sure. |
No worries.
I'm stationed in Yuma, I'm glad I'm not from this hell hole. Look me up if you are, we'll grab a beer. Going to the dunes in Cali? |
http://www.nsdn.us/index.php?option=...tpage&Itemid=1
click, scrool down^^, race we may go to in Wellton, AZ our car is the 7th pic down, my son Brian drives http://www.nsdn.us/index.php?option=...d=514&Itemid=1 |
Welton is just over the hill... I live in the foothills off exit 12. Depending on the weekend, I usually have a fresh keg of bud in the kegerator ;)
