Removing Catalyic; What Happens?
Old 04-11-2017, 09:01 AM
danalex's Avatar
I know the info is probably posted somewhere, but not sure how to search for exactly what I'm asking.
05; 2500; 4x4; Laramie.
Question: Will I create any mechanical/engine problems by removing the Cat & Muffler? and going with a straight pipe?
I believe Texas emission laws / inspections are different than California, so shouldn't be a "legal" problem....and no intention to ever cross California borders...
Question: If I do remove the Cat/muffler, will I see any positive performance changes? (MPG? power?)
thanks!
Old 04-11-2017, 06:50 PM
Danderson's Avatar
The cat has next to no flow restriction. It is a violation of federal law to remove it. Just a better flowing muffler with the cat will yield a throaty sound and will assure you will have some hearing left in years to come.
Old 04-11-2017, 09:43 PM
torquefan's Avatar
I agree. Went down the same road at one time, and gained absolutely nothing by removing a perfectly good cat. Made a noticeable difference though by swapping the factory muffler for a better flowing one.
Old 04-12-2017, 10:06 AM
danalex's Avatar
Originally Posted by torquefan
I agree. Went down the same road at one time,....noticeable difference by swapping the factory muffler for a better flowing one.
Thanks! Ref the muffler, which one did you go with, and ref "noticeable difference"--was "difference" in performance or simply sound?
Tks D
Old 04-12-2017, 09:59 PM
torquefan's Avatar
Tks D
I went with the BD muffler and tailpipe. Noticed a faster spoolup right away. Not a huge difference of course, but I was impressed (and surprised) that I could actually feel a change.
https://www.dieselperformance.com/page/homepage
Old 04-28-2017, 02:00 PM
sojoe's Avatar
My 04 did not come with a cat, so I can`t comment on the difference. BUT I can`t / won`t buy the" not restrictive" CRAP. Just cut the cat apart and you can`t help but notice that it has gotta be restrictive.
One of the main reason I shall keep my 04
By some posts I could gain mpg with a cat-----I don`t think so Tim.
Removing the cat is not legal-BUT any "greaser" knows how much better the engine will breathe.
I don`t wish to step on toes but we still have(for now) the 1st amendment.
Hell, why don`t we just drive a prius..............................
Better be careful as I know "big brother " and all his "greenies " may be monitoring!
Just my.02
Old 04-28-2017, 09:34 PM
torquefan's Avatar
Just my.02
I have measured back pressure with a gauge, on many engines (gasoline) that I suspected of having a plugged cat. If the cat is working normally, I couldn't say there was any measurable restriction, more than what a factory exhaust would provide. Granted, I wasn't able to measure while the engine was under a heavy load, but on most engines at OEM power levels, I don't think it makes a difference. Add 50 or 100 HP to that engine and that cat probably becomes restrictive; as does the muffler.
Old 04-28-2017, 11:20 PM
Danderson's Avatar
At least two guys on the TDR did dyno tests before/after cat removal. Removal of the cat yielded 4-6 rwhp per 400 rwhp made.
I wish mine didn't have one but the cat's not the restriction. The stock muffler is.
torquefan (05-03-2017)
Old 04-29-2017, 09:36 AM
CRF450R RIDER's Avatar
A number a guys have seen a slight fuel millage drop when removing their cat. 1-slightly over 1 MPG.
Old 04-30-2017, 09:30 PM
sojoe's Avatar
Golly-I think I will put a cat anf factory exh on-Happy daze and at least 1.5 MPG more.....................
Old 04-30-2017, 09:47 PM
Danderson's Avatar
Keep us informed.
death row dave (07-09-2017)
Old 05-01-2017, 12:21 AM
maybe you should do some research about these trucks and the cat. Then you'll understand there stud.
Old 05-02-2017, 11:53 AM
sojoe's Avatar
Thank you for the upgrade to "stud" status...................[duhhh
So I will remove the free wheeling hubs also + the grid heater delete + the smarty + the magnaflow exh AND keep the ehx brake engaged to increase back pressure and be good to go.......................................
Da**, I wasted all that money when all I had to do was put a cat on.
Thanks for the input
Old 05-02-2017, 04:08 PM
Danderson's Avatar
There 'ya go.
I have a Shuttleworth diesel truck muffler out of Canada. The last one yielded 11 yrs. They're expensive but a quality unit.
Old 05-02-2017, 10:38 PM
grid heater delete and the magnaflow was a waste of money, you are correct there stud. But that still has nothing to do with the cat.
Quick Reply: Removing Catalyic; What Happens?
