will it work
Old Oct 15, 2010 | 10:29 AM
95twotone's Avatar
will it work
i have a 95 3/4 ton 4x4 an im going to put a 2 inch leveling kit on it. Iv got rancho 9000 shocks. When i level it are these shocks going to be long enof and how hard is it to put a leveling kit on it
Old Oct 15, 2010 | 10:50 AM
AggieJustin's Avatar
I'd recommend the Bilstein 5100s if you're doing a leveling kit up front. I believe the Ranchos are made specifically for the stock Dodge application, so stretching them out 2" longer might give you some problems with full travel.
Old Oct 15, 2010 | 10:55 AM
95twotone's Avatar
I like the ranchos for the hauling would it be ok to have Bilsteins just up front
Old Oct 15, 2010 | 10:59 AM
Yeah, you can do the Bilsteins up front and the Ranchos in the rear. That's not a problem.
Old Oct 15, 2010 | 11:01 AM
95twotone's Avatar
ok thats what il do thanks for the help
Old Oct 15, 2010 | 11:04 AM
As for the leveling kit, it's not hard to do. You can jack the front end of the truck up and let the axle hang free. You'll probably need to disconnect the sway bar end links and watch your brake lines and vacuum lines for the front axle as well.
cheese4420
Apr 13, 2008 11:50 AM
96_12V
Jul 7, 2005 11:26 PM
Shovelhead
Aug 9, 2003 11:26 PM
AKDSLDOG
Mar 15, 2003 10:23 AM
