Very odd A/C problem
Old Jul 17, 2009 | 12:01 AM
rage_blue's Avatar
Okay so my trucks a/c system has been working very well all summer last week or so i noticed it wasn't working. After driveing around a bit i noticed that the A/C works good, down to 40 F duct them when i drive around town, back up to 60 or higher when i'm on the highway. I've never seen this issuse before and the shop i work at doesn't have guages, we just fill with redtek cans so i'm wondering if anyone else has had this issuse and can let me know what i mostlikly need to fix. Or maybe i'll end up buying some guages but i'd rather not have to right now.
Old Jul 17, 2009 | 07:50 AM
patdaly's Avatar
Sounds like it might be a bit low on freon. Shoot it with a can and see what happens.
Old Jul 17, 2009 | 11:25 PM
rage_blue's Avatar
yea i tryed that made it cool to 35f. On the way home from work today a/c was blowin like 80f so i pulled over, noticed that the a/c clutch was engauged but barly moveing, so i'll have to check for full voltage to the clutch, but i think the clutch is just bad. hopefully over filling it didn't cuase the clutch to slip. i think when i do the clutch i'll empty the system and refill it to proper spec as i don't have guages to just let some out.
Old Jul 22, 2009 | 11:17 PM
rage_blue's Avatar
okay so i bought some guages and tested the system i've got around 300psi on the high side and 30-35 on the low it was abou 25C outside, the vents were cooling to 45C I'm thinking i've got a pluged orfice tube maybe?
Old Jul 23, 2009 | 08:16 AM
patdaly's Avatar
Yep, restriction somewhere, at least you eliminate the line as a probelm when you replace the orifice.
Other possibility could be the condenser, but I highly doubt that.
You did not mean to say the vents were running at 45C, did you?
Jeff5886
18
Aug 5, 2009 03:57 AM
Boss Hoss 540
18
Nov 11, 2007 12:13 AM
xp8103
Aug 9, 2007 04:21 PM
badmrb
May 21, 2005 11:42 PM
Patrick Campbell
Aug 20, 2004 01:07 PM
