trust |
02-04-2012 06:46 PM |
I just finished changing out seat belts in my 01 QC today as part of a seat replacement and had to release the inertial reel when I let it retract to far. To replace the belt on the reel the reel will have to come out of the seat (I am assuming you are working on one with the seatbelt in the seats, if not then I dont know what I'm talking about) To remove the reel you need to skin the seat, remove a plastic piece, two torx head bolts and it lifts out of the seat frame as a unit. take the anchor end free of theseat base and thread it through the upholstery and it's out. To release the reel you take off a plastic cover with two or three clasps that hold it on. Once removed there is a ratcheting catch with a small plastic pawl that you need to gently lift away from the racheting wheel to allow for it to spin freely. Not sure how you would go about replaing the belt on the reel once you get there, probably be easier to get the whole assembly and swap it out than to try and change belts on the existing assembly. If yours is one of the earlier ones with the seat belt control module and the solenoid operated belts I can make you a great deal on the seat belts.....
