Tires are wearing, please help
Old Jul 26, 2004 | 12:12 AM
pogorules's Avatar
My original Michelin 265/85/16 tires have 56,000 miles on them. About 20,000 miles ago I noticed I was getting uneven wear on the outside edges of the tires. I had been maintaining the 45lbs air pressure that they came with and was written on the door.
I then looked closer and saw that the air pressure listed on the door was for 225's. Then I checked the tires themselves and saw I should be running 80psi. For the last 20,000 miles I have been running 80psi but the wear continues, now it is wearing on both the inside and outside edge of the tire.
What is my problem?
How can I fix it when I get new tires?
Thanks
Old Jul 26, 2004 | 01:20 AM
Dieselbuilder's Avatar
I had just gone througth the same problem. Find a good front end shop you need and alinement your toe is most likey out
Old Jul 26, 2004 | 02:23 AM
BigBlue's Avatar
Smoke the tires enough to burn them flat and then get an alignment. That's what I do.
Old Jul 26, 2004 | 04:39 AM
infidel's Avatar
The wear you decribe is quite often cured with tire balance beads. Read the thread over in products> https://www.dieseltruckresource.com/...666#post463666
Old Jul 26, 2004 | 08:17 AM
J BODY's Avatar
Wear like that is also somewhat common with a solid axle 4x4 too. Maybe your door sticker is different but on most CTD trucks I see 50 front 70 rear. I run 50 in mine unless towing the race rig then I bump them up to 70. I also have a little outer edge tire wear, and my old 95 ram did too. I never checked the 95, but I do know the 01 is pretty close. To get the alignment "nut on" on a 2500 4x4 is going to costs some $$$.
Old Jul 26, 2004 | 05:24 PM
Olratlr's Avatar
tires wearing
I have been running 55lbs Front and 45lbs Rear no hauling since new
and have 75640 miles on them and still tread left.
ronc
14
Feb 13, 2009 11:14 PM
Big Red 97'
Oct 20, 2008 02:32 PM
Little-bit
Dec 2, 2007 08:42 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
quantrill88
Mar 6, 2003 10:03 AM
