Tire Size
Old Oct 23, 2003 | 12:40 PM
TE-44's Avatar
Tire Size
I would like to know the largest tire that can be installed on a 3500 02 2wd. I have 235-85-16 now and would like the speedo to be some what right.
Old Oct 23, 2003 | 05:19 PM
Tartarus's Avatar
Re:Tire Size
Main problem is tire rubbing on the rear duallies. However, the offset is larger in the '02's than in previous years.
255-85-16 tires can be installed on the '02 3500. However, you can only find them in load range "D", and flex may be a problem with such a tall, skinny, sidewall belt-deprived tire.
265-75-16 tires can fit on an '02 3500. They're the same height as the 235-85-16 tires that come stock, but they're a bit wider. You can't go any wider than these. You can find the 265-75's in load range "E".
Not sure what you mean by the speedo being right. Should be right with 235's. Will be right with the 265's. Will be way slow with the 255's unless you program it.
Old Oct 23, 2003 | 07:04 PM
TE-44's Avatar
Re:Tire Size
Thanks for the reply, I am glad to hear the 265's will fit because that's what i really wanted to put on it. With them being the same sidewall dia. as the 235-85's it will not throw off the speedo.
oldwhite12v
Mar 25, 2011 04:28 PM
schoust
Oct 21, 2009 10:09 AM
bigdogtruck
18
Nov 21, 2007 08:09 PM
4RnrRick
Feb 27, 2007 11:25 AM
ValkSmile
Jan 23, 2007 11:42 AM
