Stock Jack and Lug Wrench Compatability
Does anyone know if the jack and lung wrench from a 1500 is the same as the one that came with a 2500? When I bought my truck the jack and lug wrench were missing and I would like to get a set for my truck from a junkyard.
Thanks,
Bob
Thanks,
Bob
X2, it's worse than useless. It will let you down just when you are down. Not sure about the 1/ 2 drive extension fitting the spare crank though as it's 6 sided.
Well I know that the stock jack will lift the truck ( stock meaning for a 2500 ) when empty but the wheel wrench that came with my truck is for a 1500. Try that out when you have a flat and the wrench doesn't fit the bigger wheel nuts. I went to Dodge and with the warranty expired they told me the I must have made the mistake. Like I would loose mine and find one for a 1500. Like said get a breaker bar, extension, and socket and be done.
The spare tire winch key is handy to have. I know the one from my 96 Dakota fit, as did one from a 98 1500. I keep a "crows foot" prybar in the govebox, as the hex-shaped handle fits right in there too.
I have a + sided lug wrench and a cheater pipe extension for it. The lugs need to be around 140# torqued and are hard to get off in the middle of the night in the rain!
My factory jack looks just robust enough for a few tries, I'd go with a 3 ton bottle jack.
Trebor
Sep 14, 2006 04:52 PM
draft cross
Apr 26, 2006 09:19 AM
