Rock Solid Steering bushing issue
I installed this earlier this year and made a big improvement in the steering wheel play. This has been flawless until recently. The issue that started recently with the cold weather is the steering has gotten tight. Every turn of the wheel i can see the gear shift move a little. This morning when I made a left turn it shifted into neutral. Is there a way to lube this bushing? Do I just need to order another and redo it?
It is likely not the bushing. I disconnected my steering shaft when working on my steering. Bushing allowed free, smooth turn without excess (any) play.
Perhaps your pump (or gear box) is failing &/or needs synthetic fluid?? |
Originally Posted by Junk Man
(Post 2870854)
Originally Posted by mr bill
(Post 2870925)
Gearbox has been replaced 3 times and not sure how it would make the gear shifter move. Been running synthetic fluid since first two AGR boxes and on Redhead. Pump has been replaced also. It's fine when its above 70 degrees. Even with the shaft loose from column the shifter moves. I'm pretty sure its the Rock Solid bushing.
I would recommend getting a hold of David and getting his opinion directly! http://www.rocksolidramtrucksteering.com/ |
Its the bushing. I installed one and it did the exact same thing when temps drop below 35*. I called them and they said it was the metal swelling due to the cold and to take it off and sand the bushing a little (can't remember if it was the inside or outside of the bushing). It did help but will still get tight if the temps get @ 25* or below. I'd give them a call and they'll help you out.
I bought one of these hoping that it would get rid of some of the steering column noise.....i never installed mine though....i wish i would have known that they don't work so well with the automatics or don't think i would have gotten it......do they work better if they are sanded down a little?
Originally Posted by mstep3
(Post 2875206)
It's not limited to autos either. I have a manual and the bushing started grabbing my steering shaft. Once it starts grabbing, don't try to lube it. That only made it worse. I wish I wouldn't have thrown away the stock parts. I finally went to the junk yard and got a new/used column. I did buy a new bushing, but I'm reluctant to install it.
Originally Posted by ldornak
(Post 2876373)
Put one on my 2001, started to bind up so I sanded off a little and it is good to go now, should have done that to start with.
Really took the slack out of the wheel. |
