power steering pump replace - help
1999 2500 4wd
I cant seem to get the power steering pump hoses off of the flared tubes coming out of the pump. Truck has 90K on it, so they might be a little stuck, but is there a trick to getting those hoses off of the pump? yeah, I moved the clips back. These are the LP hoses. The HP hose at the bottom of the pump is on a thread fitting.
Thanks
Mike in Tucson
Thanks
Mike in Tucson
Are the lines rusted so the collar wont turn? You can get a high pressure hose from most auto parts stores for under 50$ I think.
The return line is just a rubber hose over a barbed fitting, not sure if you mean this one. If it is, just slice it off and get a new hose.
Dean Snow
May 7, 2014 12:11 AM
westport
Nov 9, 2009 06:21 AM
bigyoda
Jun 12, 2007 08:34 AM
