Pass. Side Caliper Bleeding Issues
Old Jul 26, 2021 | 09:52 PM
Adam24v's Avatar
I have a 2001 Ram 2500 CTD 4x4
I replaced both calipers in the front due to one being frozen and the other being old, I was able to bleed the front driver side but I constantly get bubbles out of the passenger side caliper. I’m using a brake bleeder system and still no luck. Is there any possibility that my master cylinder is bad or should I just keep bleeding it. I have used hardly any fluid during the bleeding process and spent about 1-2 hours going back and forth trying to get it to bleed.
Old Jul 27, 2021 | 10:42 AM
texasprd's Avatar
What kind of bleeder system are you using? I've heard that if you're using a vacuum system, it's possible to pull air past the bleeder threads.
Old Jul 27, 2021 | 03:44 PM
Adam24v's Avatar
I am using a vacuum bleeder so that’s good to know. Should I use some thread tape to ensure it’s properly sealed?
Old Jul 27, 2021 | 08:19 PM
Adam24v's Avatar
Alrighty, i was finally able to get the caliper to properly bleed with a little gravity bleeding, some thread tape on the bleeder screw, a vacuum pump, and traditional bleeding
CZSteve
16
Feb 25, 2011 05:04 PM
zethtays
Dec 29, 2008 06:30 PM
dodgethis91cmns
May 6, 2008 09:56 PM
Diesel Junkie
Dec 27, 2007 08:24 PM
kingofdodge7131
17
Jun 1, 2003 07:40 PM
