NEED help (electrical/sensor)
About two weeks ago I accidentally broke off the plug in terminal below the dash on my 01. It is the terminal that is right below the cig ash tray. Anyways, it is not a big problem to fix but what i need to know is which holes that the metal wire ends need to go into. There are around 8 holes on the top row of it and 8 on the bottom but there are only like 8 total wires that go into the thing. Mine are all messed up and need some help figuring which holes they go into. Im guessing it is the BUS terminal or where they plug in to read codes. Thanks if you can help
Also wondering if anybody has a part number for a MAP sensor in an 01??
You are talking about the Data Link Connector right? If so, here are the pin assignments:
Pin 3: VT/BR wire
Pin 4: BK/LG wire
Pin 5: B/TN wire
Pin 6: DG wire
Pin 7: PK/DB wire
Pin 11: WT/BK wire
Pin 14: WT/VT wire
Pin 16: PK wire
Unfortunately I'm not sure which pin is no. 1 on that connector. Hopefully the holes are labeled with their pin number.
Pin 3: VT/BR wire
Pin 4: BK/LG wire
Pin 5: B/TN wire
Pin 6: DG wire
Pin 7: PK/DB wire
Pin 11: WT/BK wire
Pin 14: WT/VT wire
Pin 16: PK wire
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Pin 3: VT/BR wire
Pin 4: BK/LG wire
Pin 5: B/TN wire
Pin 6: DG wire
Pin 7: PK/DB wire
Pin 11: WT/BK wire
Pin 14: WT/VT wire
Pin 16: PK wire
Pin 3: VT/BR wire
Pin 4: BK/LG wire
Pin 5: B/TN wire
Pin 6: DG wire
Pin 7: PK/DB wire
Pin 11: WT/BK wire
Pin 14: WT/VT wire
Pin 16: PK wire
8\ ........ /1
16\......../ 9
The plug looks like that.
tee-ray
Jun 14, 2014 10:18 PM
bigragu
Jul 22, 2013 10:33 PM
Booost Almighty
Jan 1, 2006 01:41 PM
tobyw
20
Apr 6, 2004 11:06 PM
