My 3rd gen brake swap - PICS - 56K BEWARE!
Old Nov 3, 2009 | 05:57 PM
  #31
JasonblkZ06's Avatar
Originally Posted by nickg
i'd have to find the thread, but I believe the 3rd gen rotor (rear) fits without swaping brackets
I'll try to find the thread
Well there you go, pull a wheel and see if it all fits. If it does cool, let us know.
Old Nov 13, 2009 | 06:56 PM
  #32
CharlieFoxtrot's Avatar
That's sweet! Great writeup!
Is there anything like this for 2wd 2nd-gen? Mine's a 96...
thanks!
kevin
Old Nov 14, 2009 | 11:53 AM
  #33
2500superram's Avatar
what are these rotor's,an inch bigger?
Old Nov 16, 2009 | 01:16 PM
  #34
thanks!
kevin
No there is not anything like this for you.
The rotors are about an inch bigger, but also slightly thicker. They are MUCH MUCH heavier which in dealing with brakes is where the performance lies. Not only more surface area, but much more material to hold that heat.
Old Nov 16, 2009 | 01:17 PM
  #35
This post keeps making it back to the top, perhaps it should be stickied or a copy put in a maintenance section?
Old Nov 16, 2009 | 07:27 PM
  #36
another vote for sticky.
i'm probably gonna hunt around for the bracket's,even though no rim's to support the upgrade.
Old Nov 17, 2009 | 09:56 AM
  #37
sheriffav8r's Avatar
Do a search on "big brake upgrade" since there's a ton of info including part numbers and how-tos. When you get the calipers just make sure they have the bracket installed, too. I went with A! Cardone from CarQuest. I am interested in the rears, though, since mine need to be done soon anyway.... The rear rotor does seem to slip right off so it might be an easy upgrade.... Check out RockAuto for some good prices....
Old Nov 17, 2009 | 10:24 AM
  #38
Mcmopar's Avatar
Interesting!!
Old Apr 10, 2010 | 08:23 PM
  #39
brianpgriset's Avatar
Just finished my upgrade, I went ahead and got the calipers with with brackets from Carquest since they were so cheap ($64 after core return). The rebuilt calipers were OEM supplied TRW calipers and brackets.
Part #'s
Caliper: CLP 18-B4891
Caliper: CLP 18-B4890
Rotors: BDR 53012
Pads: FRI RMD965
Total, after returning cores was like $260, not bad. Noticeable improvement in the braking! Great mod!
Old Apr 11, 2010 | 03:16 PM
  #40
TEECARTAY's Avatar
Did your centre caps pop right on the H2 wheels?
Old Apr 11, 2010 | 07:23 PM
  #41
oldblues's Avatar
Originally Posted by JasonblkZ06
It works on 2000-2002 that have the slip off rotors.
Nothing is needed in the rears to do this swap, this is for the front only. Bias is fine, it brakes like it should have new. Feels like a car instead of a truck while braking at slow to moderate stops. If you really get on the brakes it feels like a sports car braking.
what would prevent you from doing this swap to a 94-99 if you removed the old rotor ????
Old Apr 11, 2010 | 10:55 PM
  #42
nickg's Avatar
will not work on 94-99 because caliper bracket is part of the spindel and cannot be removed, and newer spindle(00-03) cannot be swapped in because of ball joints are orentated differently
Old Dec 22, 2011 | 10:56 AM
  #43
vrj's Avatar
vrj
Just curious... Has anyone validated if the 3rd Gen. rear rotors will fit on 2nd Gen. trucks? I want to do the 3rd Gen. 17" brake upgrade to the front but want 17" rims/tires front & rear.
Are others that did the front upgrade to 3rd Gen. 17" disc brakes using stock 16" rims/tires in the rear with no upgrade to the rear ?
Thx
Old Dec 22, 2011 | 03:00 PM
  #44
dodgeguy71's Avatar
Sounds like a good upgrade that I could use. Unfortunately I'll have to buy 2 rotors, 2 brackets, new pads, and SIX 17" wheels! OUCH!! I sure am curious to see or feel the difference in the braking. My truck stays close to max weight and brakes are what are lagging on this thing.
Old Dec 23, 2011 | 12:13 AM
  #45
Thx
Yea, they have been a few guys swap the rear rotors. It is the same as the front. You can reuse your calipers, just get 3rd gen rotors, caliper brackets, and pads.
