I always wondered where that annoying rattle was coming from.....
I never could figure out where that annoying rattle was coming from the past few years....Today I found it & now I feel pretty dumb....It was the steering shaft!!!!!!!!!....Guess I should have done some reading cause I didn't realize how crappy the steering shafts are in these trucks....I don't have the steering clunk that a lot of people complain about, but it just rattles.....I'm guessing after reading that the only way to fix it is with a new Borgeson steering shaft....Are they hard to put in?
Not hard at all. Mine was very snug sliding over the gear box splines. Just be patient.
Aww I thought you were going to say it came from that Prius that got stuck in your undercarriage.
Originally Posted by VADSLRAM
(Post 2853010)
My phantom rattle was from the inner workings of the passenger seat belt clasp. Harmless but not easy to locate at first.[eyecrazy] |
(Post 2853010)
Originally Posted by mr bill
(Post 2851212)
when you put your borgeson steering shaft in did you use the existing flat spot on the steering box connection for the set screw or did you have to flatten out a new spot on the steering box for your borgeson shaft? I was just having some problems getting my steering centered using the original spot on the steering box for the set screw.... Thanks...Mike |
Originally Posted by mstep3
(Post 2861702)
hey bill,
I had a couple that was really irritating. One was the small plastic shield just in front of the steering wheel, under the bezel, sort-of. The other was the plastic rivets that holds the plastic wheel well liner in had broken off and it was flopping on wash-board areas.
(Post 2861702)
hey bill,
(Post 2863780)
Box doesnt have a flat spot on it on mine. There is a groove all around the splines and the shaft slid down to where the set screw goes into the groove.
