How to get horn chirp?
On my 2002 it says how to do it in the owners manuel, not sure if 98 is different
1.Place the key in the ignition and turn the key to the ON position(do not start the engine)
2.Press and hold the unlock button on the transmitter for four to ten seconds.
3.While the unlock button is pressed, press the lock button on the trasmitter and then release both buttons.
4.You will hear a single chime when the programming is completed.
Hope this helps.
Hope this helps.
I used those procedures to cancel the horn chirp on mine.
After I installed the air horns, I figured the neighbors wouldn't like to hear them blow everytime I locked or unlocked the truck.
Hope this helps.
Hope this helps.
I wonder if you could do it with a scan tool?
This is what works for my 01' :
Automatic Door Locks at 15mph (on/off)
1. close all doors
2. place key in ignition and cycle from off to on postition 4 times leaving it in the ON postition (do not start)
3. Press the drivers side door lock to LOCK to lock the doors within 30 seconds.
4.You'll hear a single confirmation chime when programming is complete.
5. repeat to toggle this feature.
Remote Keyless unlock all doors on first press:
1. Same as 1 & 2 above.
2. Press drivers door lock switch to UNLOCK the doors then to LOCK within 30 seconds.
3. You'll hear a single confirmation chime when programming is completed.
Horn Chirp ON/OFF:
2. Press and hold the UNLOCK button on the REMOTE for 4-10 seconds.
3. Press the LCK button on the REMOTE and then release BOTH button.
4. You'll hear a single confirmation chime whe programming is complete.
1. close all doors
Horn Chirp ON/OFF:
I use mine to lock the doors.
But I'm within a couple of feet of the truck when I do.
I can hear the doors lock.
I prefer not to let everyone in the parking lot know that I'm walking away from my vehicle.
