hot a/c, tach dancing while idling
Old May 4, 2009 | 04:52 PM
aroque137's Avatar
Hi guys, I was idling longer than usual the other day about 45 min. When I got back in the truck I noticed the a/c hotter than usual and my tach dancing between 0 and 750 with brief periods of all my interior dash lights coming on like if my truck had turned off; while all this was happening inside my truck was idling normal like if nothing was happening. Once I start rolling the a/c comes back to normal and my tach stops dancing. Now it's happens all the time when I’m idling; please help..
Old May 4, 2009 | 05:14 PM
Beast2B's Avatar
alternator bad or loose connection?
Old May 4, 2009 | 08:18 PM
aroque137's Avatar
I'm checking the alternator tomorrow but the gauge reads fine.
Old May 5, 2009 | 04:42 PM
Tate's Avatar
Could be your crank speed sensor. Bad/broken wire, out of adjustment, etc. If the PCM sees no signal from the sensor, it assumes the truck is off, so the AC will stop working, and the truck will quit charging.
Old May 6, 2009 | 11:01 AM
supr's Avatar
If you can, avoid long idles. It is bad for the motor. AC may be a little low on coolant?
Old May 19, 2009 | 07:53 AM
aroque137's Avatar
Thanks guys, I just got around to changing my crank sensor and everything is back to normal - woohoo.
aroque137
May 4, 2009 06:43 PM
scottmn1
Jul 28, 2007 05:49 PM
silverbullet02
Sep 7, 2005 04:49 PM
pogorules
Mar 15, 2005 08:59 PM
DHeadington
May 31, 2003 09:40 AM
