Help! No Lights
Old Nov 5, 2004 | 08:53 AM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
Help! No Lights
Hey guys, got in my truck and fired it up this am.....first thing I notice is I dont have any lights for my instrument cluster IE tach, speedo etc.
Then I notice I have no marker lights, parking lights or the back tail lights.....
I do have headlights, interior lights, blinkers (front and rear) and brake lights....
I checked all the fuses in cab and under dash cant find a burnt out one to save my life......
I noticed that the headlight swich pulls straight out like its supposed to but if you wiggle it around in a circle.....It is very loose.....
Can anyone help me? I need a fix by tonight as I am suppossed to go to north Washington from here in Utah and i have to have lights...
Thanks in advance, Zack
PS...Im active duty, driving around on base the MP's are real nit picky so I could really use some help.
Old Nov 5, 2004 | 10:20 AM
Lil Dog's Avatar
Just from what you describe I would suspect the light switch itself. I don't think the fuse panel under the hood has any fuses for lighting, but I am not sure. You could check that first then see about the switch..
J-eh
Old Nov 5, 2004 | 09:49 PM
cumminsdriver635's Avatar
I had the EXACT same thing happen to me. I took out the headlight switch(its new) and wiggled the connector on best i could, and they have worked fine ever since. I would check the connector, then if its bad, just go ahead and replace the switch. On my truck you just pull out the 2 screws holding on the ash tray mount thing, and then yank the cupholders out, and pull the 2 screws out of there, and the dash trim should pop of exposing the 3 screws to the headlight switch. Good luck
Eric
Old Nov 6, 2004 | 06:14 PM
pappyman's Avatar
There is a fuse for those lites in the fuse box....can't remember the fuse # but its toward the bottom of the fuse panel its a 15amp fuse
Old Nov 6, 2004 | 07:57 PM
Geico266's Avatar
Also, check the fuses with an amp meter. They can go bad and still look okay. They vibrate apart at the base. This has happened to me 3 times before I replaced all of the fues at $3.20 each.
Old Nov 6, 2004 | 10:08 PM
TomW's Avatar
He cross posted this in the "HELP" forum as well. It was the switch.
cLAYH
19
Mar 26, 2017 06:47 PM
corygale
Jul 24, 2010 11:37 AM
MoreSmoke
22
Jan 10, 2005 03:05 AM
CHarlan
Aug 6, 2003 08:40 PM
