Heater Problem.
Heater Problem.
I had a problem on the way to work this morning, I turned my heater on and i realized that the hot air was coming out of the defrost vents no matter what setting i had it on. I would put it to blow out on the floor out the front vents out both and the defrost and it wouldnt change, no matter what setting i had it on it would only blow out of the defrost vents. The low-high works, i didnt try to do it on the AC cuz its like 5 deg here. Any thoughts?
As the heater plenum "modes" are all vacuum operated, (except hot/cold) if non of them work first look for lack of vacuum usually under hood probably a line off or line worn through.
It would be wise to check all of the vacuum lines/connections. But the most common failure point is under the driver-side battery tray. The servo for the cruise is under there. Battery acid drips down on the plastic vacuum line and eats a hole in it. HTH
Not sure on the Ram but my F-250 and Dakota both have a resistor for the heater blower. When it goes bad the heater reverts to the defrost position only. Replace the resistor for about $14 and it's back to normal. I think it's mounted on firewall or under the glove box with 2ea screws.
I fixed mine last year it cost like $3 from napa for the tubbing to replace the lines, easy to find, just follow the lines, for you digman, there is one under the battery on the drivers side, and then one right under your injection pump.
rjm022
Dec 11, 2019 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
