Headlight "Flicker"
Old Jan 22, 2004 | 08:27 PM
dodgediesel4x4's Avatar
Headlight "Flicker"
Has anyone else ever seen their headlights (along w/ other electrical units) "flicker" shortly after starting your truck? Ive noticed this seems to happen in the morning when its still cold out (plugged in or not). This used to happen on my old '98 also. I do have a stereo system in my truck (as did my old one) but Im wondering if anyone else has seen this happen also. Anyone know of any possible causes? Weird.
Hunter
Old Jan 22, 2004 | 08:32 PM
phox_mulder's Avatar
Flicker, or dim/bright dim/bright.
If the latter, perfectly normal.
Grid heaters cycling.
https://www.dieseltruckresource.com/...threadid=33182
phox
Old Jan 23, 2004 | 04:31 PM
Thanks for the info.
Hunter
Old Jan 23, 2004 | 11:36 PM
J BODY's Avatar
It's as normal as the factory installed oil leak near your crank case breather bottle.
Old Jan 24, 2004 | 06:55 AM
04ctd's Avatar
understand about the grid heaters pulling power/dimming the lights,
but why does my High Beam Indicator flicker off and on VERY FAINTLY when i have the dimmer all the way down.
my old eyes are light sensitive, so i ride with the dimmer all the way down, and it's annoying because it's just bright enough to see out of the corner of your eye, looks like a SES light
Old Jan 25, 2004 | 04:49 PM
turbo thom's Avatar
Could be when the dimmer is all the way down the switch is getting to hot. When the switch is turned low, put your hand on the dash just over the switch. It can get so hot it will feel like the plastic will burn/melt. My eyes are the same but I drive bright just cause of that.
..Preston..
Old Jan 25, 2004 | 06:50 PM
GatorRam's Avatar
Don't know if this will help or not but I had a Ford that the grounds for the headlight and turning signal got loose and it caused the same thing. Just tightened them up and was good to go.
Adam
Old Jan 25, 2004 | 07:53 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Another member came up with a no cost solution to the hot switch problem.
Pull the switch out and drill a couple of holes in the dash vent duct that runs right beside the switch.
The extra air blowing across the switch will help keep it cooler.
Old Jan 26, 2004 | 11:32 PM
That is a darn good idea shovel.
hwp
Jul 5, 2011 08:41 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Common
15
Jun 15, 2007 12:13 PM
Common
14
Jun 15, 2007 11:12 AM
Extreme Diesel
Oct 23, 2002 10:23 PM
