Feedback on alignment specs please
Old Oct 7, 2006 | 12:25 PM
camocreation's Avatar
I just got my '01 2500 4x4 Quadcab CTD checked for alignment yesterday and here are the specs:
LF camber = -0.1 RF camber = +0.2
LF caster = +3.3 RF caster = +3.2
LF toe = -0.06 RF toe = +0.01
Front cross camber = -0.2
Front Cross caster = +0.1
Rear thrust angle = -0.24
**all measurements are in degrees
Are any of these for concern?
thanks,
Chad
Old Oct 7, 2006 | 01:30 PM
Hemi Dart's Avatar
Thumbs up
Compare them to this old post from the TDR, taken from Fritz's web page, written by a Mopar alignment tech:
In a previous posting written by ???? (don't remember), they were complaining about a shimmy in their Ram 4x4 after striking bumps in the road.
I suggested that the front end alignment has either too little or too much caster, thus causing a caster shimmy. He did not like my response and changed his concern from a "shimmy" to a "bounce" (big difference), and insisted it was the shocks. Maybe it is, I haven't driven it. He also said the alignment "checked out". Here's the problem:
Alignment programs (and service manuals I believe), give a wide acceptable range for front caster on the 4x4 Rams. I believe the range is 2 degrees to 5 degrees (if that's not correct, it's pretty close). The problem occurs when the alignment tech (independent or dealer) tells you that the measurements "checked out fine", just because they were in this broad range of acceptance.
Caster readings that fall on either end of the scale are subject to caster shimmy, even though they are "acceptable". I had to align some 30 trucks and attend a 9 hour "Dodge Ram Chassis Dynamics Diagnostics" training session (fancy name, ehh?), before finding out that 3 degrees to 4 degrees is the optimal caster setting for 4x4 Rams that eliminates caster shimmy.
Below I will post what specifications I set Ram trucks to. First I want to give a little more info on correct Ram alignments so you can see if you had a job well done,
The eccentrics on the lower control arms ARE NOT for individual wheel caster adjustments (even though our alignment machine says they are). The eccentric sleeves in the upper ball joints are for adjusting individual camber and total cross caster (difference in caster between two front wheels). This is why replacement eccentrics are positionable in eight different ways.
Once camber and cross caster are attained with the eccentrics, the lower control arm eccentrics are then used to swing the caster readings into specifications. The two eccentrics must be swung in the SAME direction in EQUAL amounts. If they are not, it will create a setback condition (one front wheel further forward than the other).
FYI - Comparing between the two front wheels, caster will cause a pull to the smaller value and camber will cause a pull to the larger value. A truck set up with caster pulling in one direction and camber pulling in the other direction, can lead to a wandering truck; even though it is "in specifications"!!!!!!
If the eccentrics on the lower control arms of your truck are not pointing the same direction, the alignment was done incorrectly and the axle was "twisted" or "forced" into position to attain the acceptable values (seen them from the factory this way, go figure).
A correct alignment will set the truck up with a slight negative cross caster (truck has slight pull to left) to compensate for right hand road crown. Camber will be equal side to side slightly on the negative side. This will help maintain acceptable camber when hauling heavy loads, as the truck tends to lift in the front when towing. Camber will then fall slightly positive when towing.
Just because the alignment shop says "it's in specifications", that does not mean it is set up for proper performance and handling!!!!!!!!!
Specifications (my personal settings for every Ram I align): all specs below are in degrees.
Left Wheel Right Wheel
Caster 3.2 3.5
Cross Caster -.3
Camber -.10 -.10
Cross Camber 0.0
Toe - standard specs, (maybe a little out if you tow a lot, they will pull in as the front end lifts up).
Brent
ASE Certified
Gold Certified Chrysler tech
Old Oct 7, 2006 | 01:58 PM
gmctd's Avatar
Most excellent post, Bill R. - I converted my 3500 2wd to straight front axle by sectioning in the 4wd frame, and have not found this info, not even looking in the factory manual at the dealer.
I knew enough to lock the lower eccentrics equally to the same position, so that posted data will enable correction to the final setup.
Thanks
Old Oct 7, 2006 | 02:42 PM
GSP's Avatar
GSP
I had mine aligned right after I got my truck and put on new front wheel bearings. I new the toe was alittle off at least. He adjusted the toe in and thats it, he said the rest were with in specs. Got a spec sheet ill have to compare to yours Hemi dart.
Do you adjust a different toe in spec for big wide tires. Like 305/70/16(33x12.5) or 315/75/16(35x12.5) ?
Rick
Dr. Evil
Oct 12, 2006 10:30 AM
IsItFast
Nov 14, 2005 12:47 AM
04ctd
Jun 14, 2005 06:16 PM
chsaverline
Jun 10, 2004 10:31 AM
Holycack
Sep 17, 2003 01:24 PM
