Door key hole very hard too turn
Old Jan 20, 2005 | 04:21 AM
jrs_dodge_diesel's Avatar
The battery in my remote for the alarm is dying so I have been locking the doors and using the key to get in. However my door locks are real tight. It takes some effort to turn the key. It is the same on both sides. Any ideas? Would some WD40 help out here?
Old Jan 20, 2005 | 05:26 AM
mishkaya's Avatar
I don't usually recommend WD40 as it leaves a residue. I would prefer either tri-flow which is my preferred product for this, or lock-ease otherwise. If you can't find anything better to use, WD40 will most likely help, just use it very sparingly.
Mishkaya
Old Jan 20, 2005 | 09:53 AM
infidel's Avatar
I prefer graphite lubes for the locks, no oily residue to attract and hold dust. It may go further than just the key part on your rig, sometimes you have to pop off the door panel and lube some of the inner linkages.
Old Jan 20, 2005 | 05:49 PM
phox_mulder's Avatar
Just waiting for someone to ask if it might be frozen, and try heating the key with a lighter.
(psst, he's in Guam)
phox
Old Jan 20, 2005 | 07:41 PM
phox
I am wondering if this is somewhat common. I can see one being sticky, not both. .
Old Jan 20, 2005 | 07:47 PM
DustyRock's Avatar
Maybe someone tried their key in your door and goofed it up.
Old Jan 21, 2005 | 11:01 PM
BoostdCTD's Avatar
Yup, graphite lock lube is the answer if it is in the tumbler itself.
Old Jan 22, 2005 | 06:53 AM
fireram's Avatar
My drivers side lock has not worked for a few years, didnot find that out until the battery in the remote went dead!! I have tried every lube out there, but its still stuck tight???
Old Jan 22, 2005 | 11:49 PM
Hemi Cat's Avatar
You must live in the salt belt. The best penetrating oil I have ever used is called Kroil, made by Canno products in Ky or Tenn. If that doesn't work buy a new lock.
Thedieselkid
Dec 19, 2007 03:01 PM
stealman1
Nov 9, 2007 11:07 AM
allmountainbike
Sep 11, 2007 09:11 PM
Dave88LX
Sep 13, 2005 10:45 AM
