Cold Weather Starting
Old Nov 6, 2006 | 10:02 AM
GreatTruck2001's Avatar
As the temp here in MD approaches freezing I have begun to plug my truck in overnight. I use a 1000W timer which gives power to the block heater for about 4 hours before starting.
My questions:
1. Do the heating elements heat up even when the block heater has been on?
2. Is there a way to test the block heater/heater cord to be certain they are working properly?
3. My 5 year old stock batteries clearly don't have the umph they used to. If the block heater is working properly, any suggestions on replacements?
Thanks!
Old Nov 6, 2006 | 10:32 AM
b4wheeler's Avatar
I have noticed that as the weather is getting colder, the batteries in my truck just don't want to turn her over in the morning. I have been lucky, and she has started every time so far, but I think I am in for a new pair of batteries real soon.
I have not tried plugging the truck in over night yet, but I will try that soon and see if it makes a difference.
To answer your questions, One, I believe the grid heaters are controled by the IAT sensor. Not the coolant sensor.
Two, I have heard that the block heater will actaully make some noise when it is running. I would listen for that noise and see if it is there.
As for Batteries, I am looking at a pair of Optima Yellow tops. I have had great luck with them in my other trucks.
Old Nov 6, 2006 | 10:58 AM
4x4dually's Avatar
My questions:
NO. It can't. It would drain your batteries in minutes. Too much current draw.
If you go out in a cold morning and your "wait to start light" doesn't just click on and then back off, it don't work! It should not have to wait more than a second if it is working properly.
I use a pair of NAPA spiral cells. They are made for NAPA by Exide. They are 7 or 8 year batteries and the crank speed isn't even comparable to regular water filled batteries. And they can't leak, the filling is a gel type junk. They are expensive, but they are the way to go in my opinion.
I plug my truck into a timer like you do and also set it for 4 hours before I usually leave. That is plenty of time for my truck at 25F to 40 F. If it is in the teens or low twenties, I leave it on all night, which rarely happens around here. Hope this helps.
Old Nov 8, 2006 | 10:30 AM
ccmckee's Avatar
I plug mine in when it is expected to drop below -20*c and it is on a timer as well to come 3 hrs before i leave.You can usaully hear the block heater come on, it sounds like a kettle boiling.
The grid heaters are controlled by the PCM, they will come on if the IAT senses a temp below 60*f.The heaters will both come on for startup,@ 90A each,and once the truck is running they will alternate back and forth for up to 3 minutes or you reach 20 mph.
Good batteries are a must for good cold weather starting, i just replaced mine.I also just put on a new set of grid heater relays as the old ones weren't letting enough current flow to the heaters and it was hard to start.
GreatTruck2001
Nov 6, 2006 08:03 PM
S.Dodge
Nov 4, 2006 10:22 AM
tacoma
Aug 17, 2006 03:06 AM
blueberry
Dec 22, 2005 03:55 PM
Hummin Cummins
Nov 18, 2002 12:41 AM
