codes
Old Nov 26, 2008 | 02:12 PM
jkrauss's Avatar
codes
i have three codes p0122,p1693,p0720 on my 1998.5 dodge ram 24 v diesel what do these codes meen any ideas on how to fix my proublem
Old Nov 26, 2008 | 05:26 PM
old 300's Avatar
I wish I could help you on the codes, I just checked the ones I have and I don't have a match to one of them. I have about 100 I think, well maybe not quite but none of the ones you mention.
Old Nov 26, 2008 | 06:17 PM
jkrauss's Avatar
thankyou for replying
Old Nov 26, 2008 | 06:30 PM
rolloversam's Avatar
http://www.troublecodes.net/OBD2/Pcodes.shtml
Old Nov 27, 2008 | 12:25 AM
caburnside's Avatar
P1693- not sure on that one, are you sure that is the code
P0720 Output speed sensor malfuction
P0122 Throttle position sensor (tps) / accelerator pedal position sensor (apps) signal voltage to low
That is what my repair manual has for you, but that first one is not in there are you sure it is correct?
Old Nov 27, 2008 | 01:06 AM
WestTN's Avatar
1693- DTC detected in ECM or PCM.
720- Low output speed sensor
122- APPS signal volts low
Old Nov 27, 2008 | 09:53 AM
jkrauss's Avatar
thanks for the replys very helpfull
Old Nov 27, 2008 | 10:44 AM
johnh's Avatar
p0720 is; output shaft speed sensor circuit
p0122 is; throttle position sensor A circuit low
input
p1693 is; a companion DTC was set in both the ECM and PCM
none of the codes are serious, but will require attention soon
__________________
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
