Check Gages light?
Was driving in the right lane against the curb yesterday during a much needed heavy downpour. Ended up plowing a lot of water with the truck. The Check Gage light lit up on the dash. Naturally I looked at the FP/EGT/Booast gauges and all was well. Then I realized those weren't the gauges I should be checking [duhhh]. Volt meter was reading zero. Everything else (temp, oil pressure etc) was working fine. All electrical accessories were running fine. Got home shut the truck off, waited a few seconds, turned it back on and the light was off and the voltmeter was fine. My question is this: What did I hit with the water to cause the voltmeter to go to zero volts? Did something get shorted (momentarily)?
~Rob |
Originally Posted by hotdram
(Post 1408385)
Even the connector for the crank sensor getting wet could tell the PCM the engine isn't running and turn off the alternator. phox |
As a friend of mine pointed out:
"You have a Smarty (dummy), check for codes" :) Will do, ~Rob |
