brakes
Old Jan 20, 2010 | 01:25 PM
pwregan's Avatar
brakes
just finishing up on a brake problem and have a few questions,
my rear height sensing valve brake rotted out causing my rear brakes to fail, i replaced the valve with the by-pass line and now have a closed system and am in the process of bleeding the system out- i have both the abs and brake light on the dash lit and was wondering if a thorough bleeding will reset the lights or do i need a reset of the lights?
I am going to use a motive products brake bleeder- this should provide a thorough bleeding
thanks for any help provided
Old Jan 20, 2010 | 05:27 PM
01trailerpuller's Avatar
I had a different problem but with ABS and brake light but with those lights on you need a mechanic's programmer to read and clear out the error codes. The check engine code reader will not do it.
wildcargo
Nov 29, 2005 04:20 AM
95black2615
Aug 22, 2005 09:21 AM
JImbo1
13
Apr 18, 2003 06:44 AM
