brake light fuse
Old Oct 19, 2008 | 11:12 AM
runningbird's Avatar
brake light fuse
the fuse for my brake lights burns out about 2 seconds after depresing the brake pedal. I do have a brake controler. this hapens weather or not I have a trailer hooked up. it also happens when I have no brake light bulbs in.
any idea's where to start looking?
thanks
Old Oct 19, 2008 | 08:53 PM
dozer12216's Avatar
Start at tail light wiring and work your way to front looking for damaged wiring, Left spring hangar is good place to look, but anywhere up frame rail. Generally brake controller wiring gets messed up or problem inside trailer electrical connector.
Old Oct 19, 2008 | 11:18 PM
torquefan's Avatar
Yep, work from the rear forward, unplugging stuff as you go. There are a couple of connectors involving that circuit close to the rear bumper, then at the trailer connector- have a real good look at it, then the body harness connectors under the driver door area, eventually the fuses will stop popping and you will have isolated the problem area.
I should mention: have an extra good look at any wiring that's non-factory. 70% of shorts seem to be caused by wiring that people have added to the vehicle. Trailer or camper wiring is the biggest problem area.
Old Oct 20, 2008 | 08:25 AM
thanks for the help...I'll get after it on wed.
Joey-D
Dec 12, 2011 12:52 PM
bigjohn92
Nov 25, 2010 01:32 PM
Evildiesel
Nov 18, 2005 04:12 PM
DEC
Nov 6, 2003 06:48 PM
