BEWARE potential fire hazard !!!!
Beware everybody of a potential fire hazard I've found.
I've been painting my front fenders, truck is inside my shop for past 2 days. Nothing has been "disturbed" mechanically for past month. All of a sudden I have smoke coming out from under the hood. Opened up and saw a small fire coming from left side in front of engine mount. Put it out with extinguisher (check yours, 1 of mine was dead !!!) and found out the large + positive cable from left battery to starter is anchored to oil pan by a metal strap, right in front of engine mount and above frame crossmember. I assume with time (since 2001), vibrations (after 253,000 miles) rubbed cable on metal housing and shortened it, causing a fire. Now my luck is it happened all of a sudden while I was there, it could have happened at night while asleep and burned the whole place down :o I fixed the cable and installed a different strap, with plastic insert, to avoid future fires. Please check your cables and be sure there is no rubbing or tearing. |
thanks for the info...i got some free time today and may just look at that. a metal strap on a electrical cable that has the potential to move and rub isnt the best engineering idea.
again thanks NCA |
Great information - I'll be checking mine out today as well. Do you have a photo of this strap to give just a bit more detial on what to look for? Although it should not be too hard to find.
I tossed mine since I did cut it to remove it quickly.
It is VERY obvious when you look at it, it's the only one there, approx 1" wide wrapped around + cable.. As I said my truck as many miles, thus many vibrations, a quick 5 minute inspection will save a lot of troubles. I said a big THANK YOU to the guy up there, the chances it happened on the road or while away are huge compared to when I am around truck. |
We use Adel-type clamps to mount wires, hoses, tubing, etc. - reduces NVH very well, protecting against Murphy's Law.
Just look for aluminum or SS clamps with rubber inserts! |
This is some good info... may need a sticky...
Originally Posted by Valv
(Post 1546672)
I've been painting my front fenders, truck is inside my shop for past 2 days. Nothing has been "disturbed" mechanically for past month. All of a sudden I have smoke coming out from under the hood. Opened up and saw a small fire coming from left side in front of engine mount. Put it out with extinguisher (check yours, 1 of mine was dead !!!) and found out the large + positive cable from left battery to starter is anchored to oil pan by a metal strap, right in front of engine mount and above frame crossmember. |
another thanks
im glad to see you caugth it in time too. i have been smelling random plastic burning every once in a while. i offroad my truck alot. im checing it currently. wonder if that the culprit!
Thanks.....better check mine..
