Best winter tire for heavy snowfall area and -30c temps common
get the Duratracs!, they have the mountain/snowflake symbol indicating that they meet the requirements for sever snow use, and they are pinned to accept #16 studs. they are a pretty soft tire, most likely will wear quickly, and the steering response on them is not quite as good as other tires, but they look awsome, and they will perform very well in the winter.
Wes
Wes
Mariner,
I my vote is for BFG Commercial T/A Traction load rand E and they are studable. I have run them for 2 years in AK. I will buy another set when they ware out. good luck in your hunt.
Glen
Glen
Tires
For strictly winter driving where you encounter pavement that is either exposed or snow & ice covered consider the Toyo Open Country G-02 Plus. This tire is used by RCMP in the Canadian north & is a proven performer.
If you have freeze & thaw episodes where you also encounter non paved road surfaces & & offroad mud then the Goodyear Duratrac & The Dunlop Rover Max Traction are the answer.
I used studs in the winter for decades until I discovered siping.
Now I've been studless for over 10 years.
Siping works just as well as studs, you can run the same tires all year plus your tires will last much longer.
Info> http://www.discounttire.com/dtcs/tireSiping.dos
I get by just fine in the Montana winter with siped nonaggressive thread Toyo H/T highway tires.
25k miles and seemed to have worn too quickly. I got 6 for 1250 bucks so I couldnt pass them up.
Goodyears work well because they are soft, they wear out faster, though.
Siping is great for slippery surfaces and I sipe all my tires for winter and wet driving.
Remember your dually has twice the surface area and half the weight on each rear tire, so when empty its gonna feel light and your stopping effect is going to come from the front brakes, mainly.
Traditionally, narrower tires work better in snow, you want to get down to the traction area not float on top of it.
Just my .02
Good luck.
Just my .02
Good luck.
blizzaks are good; my Pacemark snowtrakkers are the best snow tire I've ever run.
But they prob aren't heavy duty enuf for a 3/4 ton truck. If you're gona plow with it then its DEF not heavy enuf.
http://cart.airportfordlincoln.com/i...nowtrakker.jpg
Best tire I've found for my plow truck for the money is the Mastercraft Courser C/T (commercial tire).They already have some sipes in them, great tire without paying high dollar for a brand name. I take them off every spring & they've lasted 4-5 winters so far, & I can prob get 2 more winters out of them.....
[http://www.google.com/imgres?imgurl=...=1659&bih=867]
Don't forget the ballast for the dually. I haul around a 2500 block of concrete I borrowed from the driveway repair business next door. Adding chains I can go about anywhere I want in the winter here in Minn. I've had them on 6 times already this winter. The most ever.
I've had a set on my Truck for about 10000Km with no problems so far. They are E rated and wear good. The only thing I would change next time is the size 315/75/16 rub the lower edge of the fenders with the locking hub conversion I did.
