-   2nd Gen. Dodge Ram - No Drivetrain (https://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/)
-   -   Best Replacement Dashboard (https://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/best-replacement-dashboard-311983/)
jbevly May 9, 2013 01:54 PM
I was curious from the many people that have had to replace their dashboards due to cracking what they would recommend. I have seen many LMC truck parts, was just curious if people were satisifed with them, or have had better luck somewhere else. Thanks!
John
texasprd May 10, 2013 09:51 AM
Plastic Parts, Inc. in Florida makes one. I have not used it yet, but it's on my list. I do not know for certain, but that may be the one Genos sells. I'm sure there are not many companies making an actual replacement dashps/top.
high bid May 10, 2013 12:29 PM
You're looking for the full replacement....correct? Not the dash cap. I have the cap and it's now time to replace the full dash.
jbevly May 10, 2013 01:50 PM
I just need to replace the piece from the bezel around the gauges to the windshield, that's the only one that has two cracks. I like the Dash from LMC and the other piece that you can get with it that spreads the tension to a greater surface area. I just hope it is as thicker and better quality than original. Considering my truck never stays outside, I am very dissappointed to say the least with the dashboard.
toms73novass May 11, 2013 09:05 AM
I have the lmc and I am pleased with it.
mtdoragary May 11, 2013 10:57 AM
Where in Florida is Plastic Parts?
67HotRod May 12, 2013 09:33 AM
http://www.plasticpartsinc.com/dodge02.html $329 vs $239 http://www.lmctruck.com/icatalog/de/...archTerms=dash
rebal May 12, 2013 11:28 AM
I have replaced 4 with the ones Genos garage sells so far all 4 still look good and were easy to install and supposed to be lifetime warr.
matthopp May 21, 2013 07:58 AM
I have the LMC cover and it has worked fine; actual dash looked like a huge PITA to replace. My instrument bezel has a crack in it, but I added some glue to keep it tight and has worked out fine.
Sea:\>Drive May 21, 2013 11:55 AM
Put a Dodge replacement in mine a couple years ago - since I was doing A/C and heater core at the same time dash had to come loose either way. Only a day's work w/two guys - wasn't too bad. I do keep the replacement covered though - hoping to get more years than the original (which lasted 8 years).
VADSLRAM May 29, 2013 08:07 AM
LMC is OK by me.
Good price, fast shipping and a direct fit. The color was a minor shade off but that could have been my ordering a dark grey and needing a light grey.
The only suprise in my install was that the plastic pieces(go figure) that pop into the firewall and you screw the dash into were broken also. I ended up fabbing some replacements out of a hunk of HDPE I had been using as a cutting board.
jforce May 29, 2013 01:26 PM
Don't use armor all= No cracked dash. All mine are perfect. They stay that way in the Georgia sun too. I leave em dusty and they're perfect. Both 97's and now an '02 and '03. Past armor all use by a p.o. or dealer spells death down the road for your dash[nonono]
zthatzmanz28 Jun 7, 2013 07:32 AM
LMC full replacement 3 years ago. Easy to install and fit the first time without having ti trim.
