Ball Joint Replace Help
Old Mar 21, 2015 | 06:35 PM
TKulak's Avatar
97 2wd 3500. Need help or picture of what coil spring compressor you used. Thank you.
Old Mar 22, 2015 | 10:19 AM
Ronco95's Avatar
I did mine on the truck. Only lowers but used a ball joint installer and it's easy.
Only reason for spring compressor is to remove lower control arms or replace springs.
Neither operation necessary for ball joint replacement.
Old Mar 27, 2015 | 01:41 PM
VADSLRAM's Avatar
I did all 4 of mine last fall.
Best tip I can give is find someplace to rent the correct tool or some way to make your own.
I wrestled with one side literally for hours trying to get the new ones in. I figured a hammer got them out I should be able to knock the new one back in.....WRONG!!!
I found that I had a hub socket and the biggest C clamp known to man and that put the joint in.
I'm sure you should be able to borrow from a parts place or rent a hydraulic one that will make the job MUCH faster and easier.
Take my word for it. This is one time the right tool will be worth it!!
TurboRacer
Apr 16, 2009 11:10 AM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Jason West
Mar 10, 2006 11:24 AM
popeyesides
May 18, 2005 07:25 AM
