back up
back up
Where is the backup light switch on a 99. no lights thought I'd start at the switch.
Randy Bradford
www.bradfordsfiat.com
Randy Bradford
Yeah, you can just fill in your sig, so that way you don't have to keep telling us what kind of truck you have.
For an auto trans, the switch is on the transmission, on the driver's side, I think its the one near the front of the trans. Look for the Brown/Light Green (input from fuse box) and Violet/Black (output to lights) wires, those are for the backup lights.
Did you check your fuse first?
Had the same problem with my 98.5,replaced the nutral-safety switch on the tramsmission,solved my problem.This switch also controlls the backup lights.You can use a jumper on two of the three wires,green and brown I think.Turn the key on ,If it's the neutral-safety switch,lights should work.If you change the switch,be aware that it is below the fluid level.I lost about a quart .Also don't forget the metal washer. Good Luck!
__________________
__________________
07Dually
Mar 9, 2007 12:25 PM
Jordan5687
33
Feb 16, 2007 12:37 AM
JoshPeters
Apr 3, 2005 08:13 AM
Rumbles
May 24, 2004 02:26 PM
