APPS and brake light
Old Aug 14, 2008 | 07:09 PM
turbo246's Avatar
Exclamation APPS and brake light
I disconnected the batteries on my 01 and cleaned them in the process i followed the instructions on resetting the APPS by leaving the key on when you disconnect the grounds etc etc, anyways i go to start it up after all this and now i have the ABS and Brake light on at the same time and they are not going off. Any ideas? i am doin this becasue i am having convertor locking issues, my next step is to drop the pan and replace the solenoids anyone done that or have any info on it??
Old Aug 15, 2008 | 11:11 PM
dozer12216's Avatar
Key on while disconnecting the grounds?????? That is not in any service manual I've read. Must be some mechanics way of making sure has something to repair.
Perhaps a FSM could be put on your X'mas list.
Old Aug 16, 2008 | 12:55 PM
Doj Dewd's Avatar
ok, so if he was wrong - give him the correct procedure!
Old Aug 16, 2008 | 01:02 PM
Hillcountry's Avatar
I would suggest re-doing the process, but make sure the key is off. I did the same thing by accident. I disconnected the batteries, turned the key to the on position, cleaned the batteries, and after an hour went to re-connect everything, and I forgot the key was still in the "run" position. The instrument panel lit up like christmas...I just disconnected everything waited a half an hour and re-connected the batteries after I made sure the key was off. Did the reset procedure, and alll was well again. If I recall the same two lights stayed on for me also until I re-did the procedure.
I hope this helps.
Old Aug 16, 2008 | 01:13 PM
Doj Dewd's Avatar
anyone care to post the 'procedure' - or lead us the right thread?
thanx,
jason
Old Aug 16, 2008 | 07:19 PM
Sorry...the procedure is in the "Tech Facts" Section at the top of the page...under 24 valve, and listed as APPS reset procedure.
Old Aug 16, 2008 | 09:05 PM
Doj Dewd's Avatar
thanx hillcountry.
that's awesome.
Old Aug 17, 2008 | 09:11 AM
I hope it works out for you, I didn't mean to keep it a secret!
Tinkering on these trucks is fun.
Joey-D
Dec 12, 2011 12:52 PM
polaris800sp
Apr 7, 2009 10:08 AM
peak07
Nov 30, 2008 11:02 AM
mr T
Feb 24, 2007 06:42 AM
