94 Dodge Cummins Computer fryed
Old Jul 3, 2009 | 07:58 PM
canadakonrad's Avatar
Question 94 Dodge Cummins Computer fryed
hi i bought a 94 dodge cummins 3500 with the computer(pcm control) fryed in it. they some sort of by passed it to be able to charge the batteries and run some stuff. now my questian is how much is a new computer and whats all the stuff which it controlls? i got a standard tranny in it so no worries about that. also my fuel gauge is messed up? thanks for all the info.
Old Jul 3, 2009 | 10:17 PM
Lil Dog's Avatar
They must have added an external voltage regulator to the alternator. Other than than with a standard, the ECM doesn't do much other than cycle the grid heaters and run the dash gauges.
The fuel gauge being messed could be PCM related or the level sensor in the tank. They are known for getting worn or getting a loose rivot to make it not operate properly.
Old Jul 4, 2009 | 04:23 PM
exactly they added an external voltage regulator. is the grid heater the heating system? can i put any pcm in their since its a standard? (used? how much is one?) is the fuel gauge controlled by the pcm? thanks
Old Jul 4, 2009 | 08:05 PM
BigDave12768's Avatar
I doubt the PCm is fried. Its probably a bad ESS sensor. It will give you the same symptoms as a bad PCm such as no charging or A/c and such. Search crank sensors you will learn how to check it.
https://www.dieseltruckresource.com/...t=crank+sensor
abc4yew
Dec 25, 2010 03:34 PM
Chrisreyn
Oct 25, 2008 12:15 PM
Spooler
Jan 25, 2006 10:26 AM
boomer
Nov 28, 2005 07:58 PM
kellykellykelly
Oct 30, 2005 10:55 PM
